[Answered] Error with VBA code from youtube example
This thread is solved
Mike H
Greetings. Love the video for creating tabs with in tabs. I set up 12 tabs, one for each month. 24 tabs total counting the on and off. My issue is as soon as I select any month, I get a run time error. The debug shows an error with the first line of which ever tab I selected.
Here is the debug.
I followed the pattern of the template given in the article, changin the tile names, then copying each segment to reach 12 total. I made sure for which ever tile was selected the statements were True then False, with False then True on all others.
Any thoughts on what I missed? Thanks so much for any assistance! - Mike
Hello Mike,
I reviewed the screenshot of your VBA code, and I see where the issue might be originating. The runtime error you are encountering when selecting a month tab and running the associated macro can be caused by several potential problems.
This code includes checks to ensure that the shapes exist, error handling to prevent runtime issues, and unprotects the sheet if needed before making changes.
Sub JAN()
    On Error GoTo ErrorHandler
    With Sheet1
        ' Ensure the sheet is unprotected before making changes
        If .ProtectContents Then .Unprotect Password:="YourPassword"
        ' Set visibility for shapes (check if shapes exist)
        If ShapeExists(.Shapes, "JANOn") Then .Shapes("JANOn").Visible = msoCTrue
        If ShapeExists(.Shapes, "JANOff") Then .Shapes("JANOff").Visible = msoCFalse
        If ShapeExists(.Shapes, "FEBOn") Then .Shapes("FEBOn").Visible = msoCFalse
        If ShapeExists(.Shapes, "FEBOff") Then .Shapes("FEBOff").Visible = msoCFalse
        If ShapeExists(.Shapes, "MAROn") Then .Shapes("MAROn").Visible = msoCFalse
        If ShapeExists(.Shapes, "MAROff") Then .Shapes("MAROff").Visible = msoCFalse
        If ShapeExists(.Shapes, "APROn") Then .Shapes("APROn").Visible = msoCFalse
        If ShapeExists(.Shapes, "APROff") Then .Shapes("APROff").Visible = msoCFalse
        If ShapeExists(.Shapes, "MAYOn") Then .Shapes("MAYOn").Visible = msoCFalse
        If ShapeExists(.Shapes, "MAYOff") Then .Shapes("MAYOff").Visible = msoCFalse
        If ShapeExists(.Shapes, "JUNOn") Then .Shapes("JUNOn").Visible = msoCFalse
        If ShapeExists(.Shapes, "JUNOff") Then .Shapes("JUNOff").Visible = msoCFalse
        If ShapeExists(.Shapes, "JULOn") Then .Shapes("JULOn").Visible = msoCFalse
        If ShapeExists(.Shapes, "JULOff") Then .Shapes("JULOff").Visible = msoCFalse
        If ShapeExists(.Shapes, "AUGOn") Then .Shapes("AUGOn").Visible = msoCFalse
        If ShapeExists(.Shapes, "AUGOff") Then .Shapes("AUGOff").Visible = msoCFalse
        If ShapeExists(.Shapes, "SEPOn") Then .Shapes("SEPOn").Visible = msoCFalse
        If ShapeExists(.Shapes, "SEPOff") Then .Shapes("SEPOff").Visible = msoCFalse
        If ShapeExists(.Shapes, "OCTOn") Then .Shapes("OCTOn").Visible = msoCFalse
        If ShapeExists(.Shapes, "OCTOff") Then .Shapes("OCTOff").Visible = msoCFalse
        If ShapeExists(.Shapes, "NOVOn") Then .Shapes("NOVOn").Visible = msoCFalse
        If ShapeExists(.Shapes, "NOVOff") Then .Shapes("NOVOff").Visible = msoCFalse
        If ShapeExists(.Shapes, "DECOn") Then .Shapes("DECOn").Visible = msoCFalse
        If ShapeExists(.Shapes, "DECOff") Then .Shapes("DECOff").Visible = msoCFalse
        ' Set column visibility
        .Range("B:N").EntireColumn.Hidden = False
        .Range("O:FM").EntireColumn.Hidden = True
        ' Re-protect the sheet if it was protected
        .Protect Password:="YourPassword"
ErrorHandler:
    MsgBox "An error occurred: " & Err.Description, vbCritical
    Err.Clear
' Helper function to check if a shape exists
Function ShapeExists(Shapes As Shapes, ShapeName As String) As Boolean
    On Error Resume Next
    ShapeExists = Not Shapes(ShapeName) Is Nothing
    On Error GoTo 0
Key Features of the Updated Code:
Shape Existence Check:
Uses the ShapeExists helper function to ensure that a shape exists before attempting to modify its visibility.
Error Handling: Wraps the entire procedure in an On Error GoTo ErrorHandler block to gracefully handle unexpected issues. Displays a message box if an error occurs, providing details about the error.
Sheet Protection Management: Automatically unprotects the sheet at the start of the macro (if protected) and reprotects it at the end.
Visibility Management: Updates the visibility of shapes specific to "JANOn" while hiding others.
Column Visibility: Unhides the columns B:N and hides O:FM.
Hello Mike,
Sub JAN()
    With Sheet1
ErrorHandler:
    Err.Clear
    On Error GoTo 0
Thank you so much! Sorry as I am new to VBA code in Excel. I replaced the code for sub Jan and Feb to test. Error is now gone, however the spread sheet is still not changing. Still shows January either way. MAR through DEC still have error, as code has not been replaced for those subs yet. Here is how I put the code above into the program box. Was not sure if the original coding should stay as well?
Also note, my tabs do not change color when selected. Perhaps that is the issue as the "on" tab is never visible?
It seems the shapes are not reflecting the visibility changes as expected, and the sheet tabs may not be working as intended either. Here's a full breakdown and updated guidance.
Sub JAN()
    With Sheet1
        ' Unprotect sheet if protected
        ' Update shapes visibility
        UpdateShapeVisibility .Shapes, "JANOn", True
        UpdateShapeVisibility .Shapes, "JANOff", False
        ' Set other months' shapes to off
        Dim months As Variant
        months = Array("FEB", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC")
        For i = LBound(months) To UBound(months)
            UpdateShapeVisibility .Shapes, months(i) & "On", False
            UpdateShapeVisibility .Shapes, months(i) & "Off", True
        ' Show relevant columns
        ' Highlight the selected tab
        .Tab.Color = RGB(255, 255, 0) ' Highlight in yellow
        ' Reprotect the sheet
ErrorHandler:
    Err.Clear
Sub FEB()
    With Sheet1
        UpdateShapeVisibility .Shapes, "FEBOn", True
        UpdateShapeVisibility .Shapes, "FEBOff", False
        months = Array("JAN", "MAR", "APR", "MAY", "JUN", "JUL", "AUG", "SEP", "OCT", "NOV", "DEC")
        .Range("O:FM").EntireColumn.Hidden = False
        .Range("B:N").EntireColumn.Hidden = True
ErrorHandler:
    Err.Clear
' Helper Sub to Update Shape Visibility
Sub UpdateShapeVisibility(Shapes As Shapes, ShapeName As String, VisibleState As Boolean)
    If Not Shapes(ShapeName) Is Nothing Then
        Shapes(ShapeName).Visible = IIf(VisibleState, msoCTrue, msoCFalse)
    On Error GoTo 0
Double-check that every tab’s Click event points to the correct procedure and that no control names were duplicated during copy/paste, one mismatched name or missing object will throw a runtime error immediately.
Ensure that every tab's Click event is explicitly linked to its corresponding procedure in the VBA editor, as any mismatch between a control's name and the procedure it references will cause a runtime error the moment that tab is clicked. When copying and pasting controls or code during development of SSSMID, it is very common for control names to be duplicated or carried over incorrectly, which means the event handler ends up pointing to the wrong object or no object at all. Open the Properties window in the VBA editor for each control, verify that the name matches exactly what is referenced in the code, and confirm that no two controls share the same name. Even a single character difference between the control name in the form and the name used in the code will be enough to break the connection and throw an error at runtime.
cm888co
