[Solved] Excel Problem
chili
Dear All,
Please could you be able to give the solution for excel matter, problem is,
* When the excel sheet having filter with data, if we want to copy formula to Selected filter column, its not properly pasted to filter Colum. Please advise for this
Dear All,
Dear Chili,
Welcome to ExcelDemy Forum! We apologize for the late reply and thank you for explaining your problem in brief words. However, it would be really easier for us to understand better if you could share your Excel file.
As we understand, you are facing issues to copy-paste formulas in a Filter column. This is because Excel does not allow pasting to cells in a range that contains hidden rows or columns (which, in our case, has hidden rows). Thus, it shows the below error message.
Fortunately, we can find an alternative way to overcome this issue. Follow the steps below:
  • In the beginning, select cell E6 as this is the value we want to paste in the filtered column. Do the same if you are working with a formula.
  • Afterward, press the Ctrl and C keys together to copy.
  • Next, select the cells in the filtered column where you want to paste the E6 cell value.
  • Further, press the F5 key or the Ctrl and G keys together to call the "Go to" dialogue box.
  • There, select Special.
  • Meanwhile, in the Go To Special dialogue box, select Visible cells only and press OK.
  • Lastly, press the Ctrl and V keys together to paste the value and it’ll return the desired result.
  • Eventually, if you remove the Filter feature, you’ll see the new value only in the visible cells of the previously filtered column.
I hope this helps you. If not, we would really appreciate your reply here with a demo dataset. Good luck!
Dear Chili,
Thank you very much for support
