Formula to pull names based on 2 columns
SGustaveson
I am making score sheets for rodeo kids pulled from the sign-up sheet. I need to pull the first then last name of the kids in different age groups based on which days they will compete. I would like to do this automatically, so we are not doing this by hand every event. The selections remain the same every rodeo as they are in a google form that we export into an excel. I would like to save the file in the same name as the file before so that the formula's remain the same on the score sheets, it is just different data pulled in.
Sign-up Sheet Options below
First nameLast NameBarrel RacingDays you are competing
BellaSmithTiny TotSaturday only
SuzieHanesTiny TotBoth days
JenniferRehaTiny TotBoth days
SaraPikeSenior, OpenBoth days
KinzyRooseSenior, OpenBoth days
KatieRubinSeniorSunday only
FallonPlathSeniorBoth days
EmmaSmithNovice, OpenBoth days
AveryHanesNovice, OpenSaturday only
Score sheets are separated by day and by age group.
Tiny Tot - Saturday
FirstLastTime Ran (This is written in by hand at the rodeo)
BellaSmith
SuzieHanes
JenniferReha
Tiny Tot - Sunday
SuzieSmith
JenniferReha
You can see that Bella Smith is not on the Sunday Score sheet as she is not running. I can use the filter formula to pull all the names that say Tiny tot easily enough but struggle with the fact that not all of them will always be running.
Additionally, the other categories have the option to run in 2 categories if they want to. It pulls them in as Senior, Open instead of 2 different lines or different rows. I would like to learn these formulas and understand how they are functioning. Additionally, I have the option to change the sign-up sheets if you see a different way to categorize these so that it is easier in a formula. I thought about changing the days to 2 different selections where then it would be sat and Sunday presented in different columns and an N/A for those that are not selected.
I would love to meet with someone on Microsoft teams to go through this if that is an option as well!
Hello SGustaveson,
Hi there! You're doing a great job organizing the score sheets, and automating this in Excel is doable and can save tons of time!
To make your process smoother and formulas more reliable, I highly recommend updating the sign-up sheet format just a bit. Specifically:
Split the "Days you are competing" into two columns: Saturday and Sunday, marked as "Yes" or left blank.
Split multi-category events like "Senior, Open" into two columns too: e.g., Senior, Open.
Once that’s set up, you can use the FILTER function (if using Excel 365/2021) to pull the names dynamically into your score sheets based on both category and day.
For example:
=FILTER(SignUp!A2:B100, (SignUp!C2:C100="Tiny Tot")*(SignUp!D2:D100="Yes"))
That pulls the first and last names of all Tiny Tot kids running on Saturday.
If you're open to sharing a sample sheet, I can help you write the exact formulas based on your setup. Also, using named ranges and saving over the previous file (as you mentioned) is a great idea to keep your score sheets auto-updating with fresh data.
LunaXX
