[Solved] Nested If function not working
cashby
How do i get this nested IF function working?
=IF(E15>$M$15,$N$15,IF(E15>$M$16,$N$16,IF(E15>$M$17,$N$17,IF(E15>$M$18,$N$18,0))))
Hello Cashby,
Your nested IF is working syntactically; it’s the logic/order that’s wrong. Right now, you test the lowest tier first (M15 = 12,522). Since E15 (66,422 in your sheet) is already greater than 12,522, Excel returns N15 immediately (4%) and never reaches the higher tiers (5%, 6%).
Fix 1: Keep Nested IF, but check from highest to lowest
=IF(E15>$M$17,$N$17,
IF(E15>$M$16,$N$16,
IF(E15>$M$15,$N$15,0)))
(Use the highest threshold first, then move down.)
If you want the threshold itself to qualify, use >= instead of >.
Fix 2 (Best/Cleanest): Use LOOKUP (tiers must be sorted ascending)
If M15:M17 are your tier thresholds in ascending order, this is much simpler:
=LOOKUP(E15,$M$15:$M$18,$N$15:$N$18)
This returns the payout for the largest tier that is ≤ E15 (so 66,422 will return 6%).
Quick checks:
  • Make sure M15:M18 are real numbers (not stored as text).
  • Keep the tier values in M sorted from smallest → largest (LOOKUP needs that).
MUY buenas tardes, también podríamos usar nombres y fórmulas comparativas:
Y(E4>=MONT1;E4<MONT2)*PORC1+Y(E4>=MONT2;E4<MONT3)*PORC2+Y(E4>=MONT3;E4<MONT4)*PORC3+Y(E4>=MONT4)*PORC4
Hello JORGE W. ROSERO,
Thanks for sharing your suggestion. Using a nested IF formula can definitely help handle multiple conditions in this case. Just be careful with the structure and parentheses, since a small mistake there can cause the formula not to work properly.
In many cases, the issue with nested IF formulas happens because:
  • A parenthesis is missing
  • The logical tests are not ordered correctly
  • Or the formula becomes too complex to manage
If the number of conditions is large, another option is to use IFS (in newer Excel versions) or create a lookup table with VLOOKUP/XLOOKUP, which can make the formula easier to maintain.
Appreciate your input in helping solve the problem.
Hello Cashby,
IF(E15>$M$16,$N$16,
This returns the payout for the real money live casino tier that is ≤ E15 (so 66,422 will return 6%).
Quick checks:
Good explanation - the early TRUE short-circuit is what trips most people up with nested IFs. The LOOKUP approach is definitely cleaner for tiered values like this.
Hello TrevorWestbrook,
Thanks for your feedback. Keep contributing on the ExcelDemy forum to help each other.
kqbdvcom
