[Solved] Additional VBA for working with Excel Shapes
Sam6284
I'm referring to Musiha Mahfuza Mukta excellent article "How to Perform Drawing of Objects with VBA in Excel (2 Easy Examples)" posted 12/24/23.
Context: I've created a right triangle shape, filled it with a pattern, and named it "Mountain". I now only need to refer to it in VBA as ActiveSheet.Shapes("Mountain") followed by a dot for methods/properties.
I'm confused with some of the answers I've found.
I want to do two things with this shape in VBA using values in named cells:
1) Set it's height named Gain_M (single) and width named AB (for it's trig id, also single)
2) Move the lower left corner to cell "D11". I'll give it a name, too, eventually.
If there's more examples on sizing and positioning Excel shapes that can be squeezed in, that'd be a plus. All I need is 1 and 2.
Hello Sam6284,
Here's how you can set the height and width of the shape and move its lower-left corner to cell D11.
To set the Height and Width use the following VBA code.
With ActiveSheet.Shapes("Mountain")
    .Height = Range("Gain_M").Value
    .Width = Range("AB").Value
To Move the Lower Left Corner to D11 use the following VBA code.
    .Top = Range("D11").Top + Range("D11").Height - .Height
    .Left = Range("D11").Left
This code sets the shape's height and width based on the values in the named cells Gain_M and AB and then moves the shape so its lower-left corner aligns with cell D11.
