[Solved] Conditional formatting (Need highlight county names)
MISAJ
Hello All,
Need help with highlighting county names
i have data available in sheet 1 (around 50 County names) and in sheet 2 i have few counties which will match with sheet 1 and whenever i type the sheet 2 county names in sheet 1 that name or row should highlight in sheet county row only
Hello Misaj,
To highlight the country name of sheet 1 if it exists in sheet2, you can follow these steps:
  • Go to Sheet 1 and select the range (select the range A2:A90 ).
  • Click on the Home tab >> from Conditional Formatting >> select New Rule.
  • In the New Formatting Rule window, select Use a formula to determine which cells to format.
  • In the formula box, enter the following formula:
    • =ISNUMBER(MATCH(A2, Sheet2!A:A, 0))
  • Here, A2 is the first cell of the column. The formula checks if the county name in Column A of Sheet 1 exists anywhere in Column A of Sheet2.
  • Click on Format, choose your desired formatting (e.g., a yellow background color to highlight the matches), and press OK.
  • Press OK again to apply the rule.
Thank you.
Taken same formula and cells are highlighting but not highlighting the same cell going to the above cell or previous cell
If i type Lake (which is available in sheet 2) above line (India) is highlighting
The problem of not highlighting the same cell going to the above or previous cell occurs when your cell reference is not aligned with your dataset.
Adjust your formula:
Try with:
=ISNUMBER(MATCH(A1, Sheet2!A:A, 0))
=ISNUMBER(MATCH(A3, Sheet2!A:A, 0))
Based on which cell your country name starts,
Try with:
Thank you for the help
SprintzEd21
