brandy.chapman
Hi! I watched your video and read through your article in regards to how to create a search box utilizing VBA code.
This video was very informative and helped me understand the code well enough to apply it to my own conditions, outside of one area. Line item under PartialMatch "For i = 1 To Len(Value2)" I am getting an Error 13 of mixed match type. I've read through some forums and tried to understand the error code, but can't figure out where inside the code this would trigger an issue with my spreadsheet.
Sub SearchMultipleSheets()
Main_Sheet = "CommunitySearch"
Search_Cell = "B3"
SearchType_Cell = "C3"
Paste_Cell = "B9"
Searched_Sheets = Array("Master", "LandDev", "StartSalesClosings", "Entitlements", "LDScheduleDates", "LDActualDates", "Variances")
Searched_Ranges = Array("A2:Z250", "A2:Z250", "A2:Z250", "A2:Z250", "A2:Z250", "A2:Z250", "A2:Z250")
Copy_Format = True
Last_Row = Sheets(Main_Sheet).Range(Paste_Cell).End(xlDown).Row
Last_Column = Sheets(Main_Sheet).Range(Paste_Cell).End(xlToRight).Column
Set Used_Range = Sheets(Main_Sheet).Range(Cells(Range(Paste_Cell).Row, Range(Paste_Cell).Column), Cells(Last_Row, Last_Column))
Used_Range.ClearContents
Used_Range.ClearFormats
Value1 = Sheets(Main_Sheet).Range(Search_Cell).Value
Count = -1
If Sheets(Main_Sheet).Range(SearchType_Cell).Value = "Case-Sensitive" Then
Case_Sensitive = True
ElseIf Sheets(Main_Sheet).Range(SearchType_Cell).Value = "Case-Insensitive" Then
Case_Sensitive = False
MsgBox ("Choose a Search Type.")
For S = LBound(Searched_Sheets) To UBound(Searched_Sheets)
Set Rng = Sheets(Searched_Sheets(S)).Range(Searched_Ranges(S))
For i = 1 To Rng.Rows.Count
For j = 1 To Rng.Columns.Count
Value2 = Rng.Cells(i, j).Value
If PartialMatch(Value1, Value2, Case_Sensitive) = True Then
Count = Count + 1
Rng.Rows(i).Copy
Set Paste_Range = Sheets(Main_Sheet).Cells(Range(Paste_Cell).Row + Count, Range(Paste_Cell).Column)
If Copy_Format = True Then
Paste_Range.PasteSpecial Paste:=xlPasteAll
Paste_Range.PasteSpecial Paste:=xlPasteValues
Next j
Next S
Application.CutCopyMode = False
Function PartialMatch(Value1, Value2, Case_Sensitive)
Matched = False
If Case_Sensitive = True Then
If Mid(Value2, i, Len(Value1)) = Value1 Then
Matched = True
If Mid(LCase(Value2), i, Len(Value1)) = LCase(Value1) Then
Matched = True
PartialMatch = Matched
Search_Cell = "B3"
Paste_Cell = "B9"
Copy_Format = True
Count = -1
Count = Count + 1
Rng.Rows(i).Copy
Next j
Next S
Matched = False
Matched = True
Matched = True
