[Solved] Data Update Issue
Dear,
Kindly see the attached file;
Summary sheet has collection of certain data from each sheet in the worksheet.
1. When UPDATE button is clicked it updates whole data in the sheet. but i need to only add new record when new sheet is added and not to rewrite the whole data again in summary sheet. Kindly help
2. The "Batch" column is linked with each sheet to go directly to that particular sheet when clicked. It does not work for all the sheets ( last 02 sheets it does not work, while code is the same).
Dear,
Hey mfaisal.ce,
Thank you for your question. You can use the following code instead of the code you used. Here, I have made some small changes to your code.
Sub Update_Record()
'Procedure to Consolidate all sheets in a workbook
On Error GoTo IfError
'1. Variables declaration
Dim Sht As Worksheet, DstSht As Worksheet
Dim DstRow As Long, v As Integer
'2. Disable Screen Updating - stop screen flickering
' And Disable Events to avoid inturupted dialogs / popups
With Application
.ScreenUpdating = False
.EnableEvents = False
Set DstSht = Worksheets("Summary")
DstRow = 3
'5. Loop through each WorkSheet in the workbook and copy the data to the 'Consolidate_Data' WorkSheet
For Each Sht In ActiveWorkbook.Worksheets
If Sht.Name <> DstSht.Name Then
'5.1: Find the last row on the 'Consolidate_Data' sheet
DstRow = DstRow + 1
If Sht.Range("B5").Value = DstSht.Range("B" & DstRow).Value Then
GoTo txt
Sht.Range("B5").Copy
DstSht.Range("B" & DstRow).PasteSpecial Paste:=xlPasteValues
Sht.Range("D3").Copy
DstSht.Range("C" & DstRow).PasteSpecial Paste:=xlPasteValues
Sht.Range("G3").Copy
DstSht.Range("D" & DstRow).PasteSpecial Paste:=xlPasteValues
Sht.Range("F5").Copy
DstSht.Range("E" & DstRow).PasteSpecial Paste:=xlPasteValues
Sht.Range("F6").Copy
DstSht.Range("F" & DstRow).PasteSpecial Paste:=xlPasteValues
Sht.Range("F7").Copy
DstSht.Range("G" & DstRow).PasteSpecial Paste:=xlPasteValues
Sht.Range("F8").Copy
DstSht.Range("H" & DstRow).PasteSpecial Paste:=xlPasteValues
ActiveSheet.Hyperlinks.Add Anchor:=DstSht.Range("C" & DstRow), Address:="", SubAddress:="'" & Sht.Name & "'" & "!A1"
txt:
Next Sht
IfError:
'6. Enable Screen Updating and Events
With Application
.ScreenUpdating = True
.EnableEvents = True
Firstly, I have deleted the ClearContents method to stop deleting existing data from the summary sheet. Then, I used an If Statement to check if the cell contains the same data. If it contains the same data then it will go to the next sheet. You will have to add the new sheet at the end of all the existing sheets in your excel workbook and you will get your desired output.
Secondly, I changed the subaddress in the Hyperlinks.Add method.
I hope this will solve your problem. I have also added the Excel file here. Please let us know if you face any issues.
Mashhura Jahan
Hey mfaisal.ce,
Sub Update_Record()
With Application
DstRow = 3
DstRow = DstRow + 1
GoTo txt
txt:
Next Sht
IfError:
With Application
Mashhura Jahan
Thanks a lot. It helped and solved my issue. is it possible to make a progress bar while refreshing/updating the records?
Hello mfaisal.ce,
Thank you for your feedback. Showing a progress bar while refreshing/updating the records is possible.
Firstly, open the Visual Basic Editor >> select Insert tab >> select UserForm.
Then, change the Caption, Height, and Width of the UserForm according to your preference from the Properties window. The Properties window is located on the left side of the screen.
After that, select Label from the Toolbox >> click and drag your mouse cursor where you want to place the label. Then, change the Caption, Height, and Width of Label1 according to your preference from the Properties window.
Afterward, insert a Frame in the same way. Keep the Caption blank for Frame1. And, change the Height, and Width according to your preference from the Properties window.
Next, add another Label and place it on the frame. Change the BackColor of the label. Here, I kept it Highlight. And, left the Caption blank for Label2.
At this point, the UserForm will look like the following image. Right-click on the UserForm >> select View Code.
Then, write the following code in UserForm1.
Private Sub UserForm_Activate()
Call Update_Record
Here, Update_Record is the sub procedure you used for updating the records. Now, write the following code instead of the code you used before.
Sub Update_Record()
Dim prog_compl As Single
With Application
DstRow = 3
i = 1
DstRow = DstRow + 1
GoTo txt
txt:
prog_compl = (i / ThisWorkbook.Sheets.Count) * 100
progress_bar prog_compl
i = i + 1
Next Sht
IfError:
With Application
Unload UserForm1
Sub progress_bar(prog_compl As Single)
UserForm1.Label1.Caption = prog_compl & "% Completed"
UserForm1.Label2.Width = prog_compl * 2
DoEvents
Here, I have modified the code a little bit. I have added the marked portions you can see in the following image.
Now, open another module >> write the following code.
Sub show_userform()
UserForm1.Show
After that, assign the macro named show_userform to your CommandButton.
Finally, you will be able to see the progress bar whenever you click on the Update button. You can close the progress bar manually by pressing the cross button when it says “100% Completed”.
If you want to close the progress bar automatically once the whole record is updated then you can add the following line in the code.
I hope this will solve your problem. I have also attached the excel file for your convenience. Please let us know if you face any other problems.
Mashhura jahan
  • R-301.xlsm
    R-301.xlsm
