[Solved] Extracting a Number from Strings
MartyMcFly
Hi there, Can someone help me please ?
how do i extract a number if it has a text before it and a full stop after .... for example, the cell says "Money Out (£) 8.46." All i want is the numerical value of "8.46", please let me know, thanks in advance !
It could be to extract the number from the cell to a new cell or to replace the cell with just the number ? anyway is okay as i can move the value over afterwards
Dear MartyMcFly
Welcome to ExcelDemy Forum! Thanks for reaching out and sharing your problem with such clarity.
Assuming you have a cell containing values like "Money Out (£) 8.46," you want the numerical value only. You need to extract numbers from cells and insert them into new cells (this can easily be done by applying Excel Formulas) or replace the cell values with numbers (this can quickly be done by running Excel VBA Code).
Don't worry! We have demonstrated your situation in a workbook and solved both problems.
SOLUTION Overview:
Extracting the number from the cell to a new cell or replacing the cell with just the number.gif
Excel Formulas:
=VALUE(MID(B5, FIND(") ", B5) + 1, FIND(".", B5, FIND(".", B5) + 1) - (FIND(") ", B5) + 1)))
Excel VBA Code:
Sub ReplacingCellValueWithNumber()
    Dim selectedRange As Range
    Set ws = ThisWorkbook.ActiveSheet
    Set selectedRange = Application.Selection
    If selectedRange.Columns.Count > 1 Then
    For Each cell In selectedRange
        If cell.Value = "" Then
            GoTo endOfALoop
        Dim numText As String
        numText = Mid(cell.Value, InStr(cell.Value, ") ") + 1, InStr(InStr(cell.Value, ".") + 1, cell.Value, ".") - (InStr(cell.Value, ") ") + 1))
        cell.Value = CDbl(numText)
endOfALoop:
I have attached the solution workbook for better understanding. Stay blessed.
Excel & VBA Developer
  • MartyMcFly (SOLVED).xlsm
