[Solved] How to remove object from cells.......
Hello Paps6,
Thanks for sharing your problem with us. The diamond shape in the top left corner of the cells of your worksheet is Error Checking Indicator. This shape appears because you have stored numbers as text in your workbook.​
There are two ways to resolve this problem.
Solution:1
First, go to the File tab.
zb_62iGXEKNCq6Ocw3Stnj71v6EhI4703jLaT3AFv5xsNdq4F6UGrS3MSAMh5R_bZS2GPWH68CogFWjhMMCBT3Dxlrg5fIJHveDAf1knXBtUrciWfubVW8aFpzeM0NJyiVuz8U9Krt7Q4yplSqM_wyQ
Then, click the Options command.
LmPNYxIM7q33sLWCZatDIC2MN2os9ffKIQDjzBYZEg4t5_xGpuAZkfPUZMEVsGUXvCJERdEPr3sNs_a4voq6s21io4LpeXffljPTWOYsbXuBDdhM2D_K-fKHItO8zAjIfxndoayY4ZSMJ_gO2bvGVRc
In the Excel Options dialog box, go to the Formulas menu >> disable the Enable Background Error Checking option >> click the OK button.
twmCvGf_tQkpdsqr5_XE-wvyvEhAEqJKVQsz8lENZc1bkdSiygiBExkfF9PKmHmEpdrjyXBssHoqT42iA49jCCmnmg1a_5pDbr0P6IbOIzqLpkYcqQ6Uiz5EpcvKQ6nxoWh7-rGmUg_kC5R0r8UxhF0
The Error Checking Indicators won’t appear now.
Solution:2
If you don’t want to disable the Background Error Checking, then select the range for which the Error Checking Indicator appears (i.e. range B2:B166) >> click the Error Checking Indicator >> Select the Ignore Error command.
sAiu88wwocB_8eCzTE6_ivz7Biyiadgg_bPo-cl50mDWlW0-fzNMKrBX8nee1HzE0dfARnm_83aaF9RR0IlzaATvBhvfo9m_DNMrQAO3bVmi-FYCfxxg7xdWw8-ILzxHWw_Kp71rMtgBspH2dBuzIUc
Now, the Error Checking Indicator is not visible for the selected range. Repeat this for other ranges as well.
32ATB8Iyu4cCTv6BPjDK_ookl2GuZTe6nybbsc08dRiqLp-aGe4tn-Ed9oJCGNi-IYIzKTLde9pmF2Mt9dJGt35yOXScT7GwSe5SoSsMCBXjIXnOt5JDkHp7KjTi6V1HylNLNBbKJPkb3Xo8Gfhv820
Hopefully, this resolves your problem. Let us know your feedback.
Trade Fex Signal Pro
