[Solved] How to Sum dynamic multiple range
hello,
kindly help me please, how to sum data in dynamic multiple range? thank you.
Hello BigMe
Thanks for sharing your problem. I want to sum up multiple dynamic ranges. Assuming the row of each range may vary from time to time. I am presenting an Excel VBA Event Procedure that will trigger when any values change with column B.
Follow these steps:
Step 1: Right-click on the sheet name tab => Click on View Code => Paste the following code in the sheet module => Save.
    Dim totalCell As Range
    Dim totalRange As Range
    Dim sumTotal As Double
    Dim lastRow, startRowTemp As Long
    Set totalRange = Range("B2:B" & Cells(Rows.Count, 2).End(xlUp).Row)
    startRowTemp = 2
    If Not Intersect(Target, totalRange) Is Nothing Then
        For Each cell In totalRange
            If InStr(1, cell.Value, "Total") > 0 Then
                lastRow = cell.Row
                sumTotal = Application.WorksheetFunction.Sum(Range("C" & startRowTemp & ":C" & lastRow - 1))
                Set totalCell = Cells(lastRow, 3)
                totalCell.Value = sumTotal
                startRowTemp = lastRow + 1
Step 2: Return to the Sheet => Make changes to see the desired output like the following GIF.
Hopefully, the shared code will fulfil your requirements. Good luck!
Dear Lutfor,
thank you for your response, is this code can run if i copied to a module? because i want to merge & modify with other macros, thank you
bigMe
Dear Lutfor,
bigMe
Dear BigMe
Thanks for your queries. Unfortunately, you can not keep that code in a module. You must keep the code in the sheet module because the previous code is an Event Procedure.
However, we can modify the previous code and turn that into a Sub-procedure.
Excel VBA Sub-procedure:
Sub SumDynamicMultipleRange()
    startRowTemp = 2
            lastRow = cell.Row
OUTPUT OVERVIEW:
I hope the Sub-procedure will fulfil your requirements. Good luck
