[Solved] INDEX+MATCH
ROKTOBONDHU
I am trying to use this formula INDEX(MATCH)... But it's not working for me for some reason... I am using 2016 version of office 365 on my pc... When I used the same formula on my mobile it is working....
Dear Roktobondhu
Welcome to ExcelDemy Forum! Thanks for reaching out and sharing your problem.
You are facing difficulties with an INDEX-MATCH formula. You mentioned that it works on your mobile device but not your PC, which uses Excel 2016.
I have reviewed your formula and found that it is an array formula. In Excel 2016, array formulas need to be entered using Ctrl+Shift+Enter, not just Enter. On the other hand, Mobile versions of Excel, especially in newer releases, may have built-in functionality to handle specific array formulas.
I hope these ideas will help you overcome your situation. Good luck.
William Tang
