[Solved] Question about conditional counting
jznance
Good day,
I am sorry if this question has been addressed before, I have done a search in what time I have available at work and could not find anything that specifically highlighted this concern.
My question comes from a need to count individuals and keep a running number of consecutive entries. Full disclosure, it is a tardy tracker for a school that has been maintained by hand up to this point, but I would like to automate the process.
So I would like to be able to have a master list by name and total count on one spread sheet. On another sheet I would like to be able to enter a name (by date) and have the total count on sheet 1 track the cumulative name entries on sheet 2.
Is it possible to have a conditional count based on name text entry?
Thank you all.
Hello Jznance,
Thank you for your question! You can achieve this in Excel using a combination of COUNTIF or COUNTIFS formulas to track and count entries based on names across different sheets.
Here’s how you can set it up:
Master List (Sheet 1):
  • Have a list of names in one column (e.g., Column A).
  • In the adjacent column (e.g., Column B), use the COUNTIF formula to count occurrences of each name from Sheet 2.
  • The formula will look something like this:
=COUNTIF(Sheet2!A:A, A2)
This will count the number of times the name in A2 appears in Column A of Sheet 2.
Input Sheet (Sheet 2):
You can enter the names along with the date or any other details in the relevant columns. For each name entered, the COUNTIF formula in Sheet 1 will automatically update to reflect the cumulative count.
This will allow you to automate tracking the cumulative number of entries for each individual.
I hope this helps! Let me know if you need further clarification.
This is wonderful! Thank you so much for your help. I was able to get them to work. This will hopefully streamline the incoming tardy students well, and give back more class time. I appreciate your help
huroy771
