=SORT(UNIQUE(FILTER(FILTER(C4:C33,ISNUMBER(FIND(D433&E4:E33,TEXTJOIN(" ",,K4:K6&J4:J6)))),BYROW(FILTER(C4:C33,ISNUMBER(FIND(D433&E4:E33,TEXTJOIN(" ",,K4:K6&J4:J6)))),LAMBDA(r,SUMPRODUCT((FILTER(C4:C33,ISNUMBER(FIND(D433&E4:E33,TEXTJOIN(" ",,K4:K6&J4:J6))))=r)*1)=3))))) |
[td width="194pt"]
Dear All
[/td][td]
I kindly request, if possible, to replace Lambda function with another Since some of our colleagues are not completely familiar with the Lambda function, I would appreciate it if you could replace it with another
[/td][td]
this formula pull data from a table if two criteria are met
[/td][td]
many thanks
[/td][td]
Formula in Cell G4
[/td]
