Sub generateReviewReport()
'declare your required number of file path variables
Dim file_path1, file_path2, file_path3, file_path4 As String
Dim file_pathArr() As Variant
'Assign file paths to the declared variables
file_path1 = "F:\Exceldemy\FQ-182\Folder 1\First Reviewed Spreadsheet.xlsx"
file_path2 = "F:\Exceldemy\FQ-182\Folder 1\Second Reviewed Excel File.xlsx"
file_path3 = "F:\Exceldemy\FQ-182\Folder 2\Third Reviewed Excel File.xlsx"
file_path4 = "F:\Exceldemy\FQ-182\Folder 3\Fourth Reviewed Spreadsheet.xlsx"
'update the array with all file path variables
file_pathArr = Array(file_path1, file_path2, file_path3, file_path4)
Dim lb, ub As Integer
lb = LBound(file_pathArr)
ub = UBound(file_pathArr)
Dim i As Integer
Dim file_nameArr() As Variant
ReDim file_nameArr(lb To ub)
Dim start_loc, end_loc As Integer
For i = LBound(file_pathArr) To UBound(file_pathArr)
start_loc = InStrRev(file_pathArr(i), Application.PathSeparator)
end_loc = InStr(file_pathArr(i), ".")
file_nameArr(i) = Mid(file_pathArr(i), start_loc + 1, end_loc - start_loc - 1)
Dim wb_name As String
Dim msg As String
Dim lastRow, lastCol As Integer
Dim j, k As Integer
Dim font_color As String
Dim font_strike As Boolean
Dim cell_value As String
Dim count_red, count_strike As Integer
For i = lb To ub
Set wb = Workbooks.Open(file_pathArr(i))
If Len(file_nameArr(i)) <= 15 Then
wb_name = file_nameArr(i)
wb_name = Left(file_nameArr(i), 15)
For Each sh In wb.Sheets
lastRow = sh.Cells.Find("*", SearchOrder:=xlByRows, SearchDirection:=xlPrevious).Row
lastCol = sh.Cells.Find("*", SearchOrder:=xlByColumns, SearchDirection:=xlPrevious).Column
Set rng = sh.Range(sh.Cells(1, 1), sh.Cells(lastRow, lastCol))
For Each cell In rng
count_red = 0
count_strike = 0
font_color = "not red"
font_strike = False
cell_value = cell.Text
For j = 1 To Len(cell_value)
If cell.Characters(j, 1).Font.Color = RGB(255, 0, 0) Then
font_color = "red"
count_red = count_red + 1
If cell.Characters(j, 1).Font.Strikethrough = True Then
font_strike = True
count_strike = count_strike + 1
font_strike = False
Next j
If font_color = "red" And count_red = Len(cell_value) Then
If font_strike = True And count_strike = Len(cell_value) Then
msg = "Sheet: " & sh.Name & ", Cell: " & Join(Split(cell.Address, "$"), "") & ", Complete Red and Strikethrough"
updateReport wb_name, msg
If font_strike = True And count_strike <> Len(cell_value) Then
msg = "Sheet: " & sh.Name & ", Cell: " & Join(Split(cell.Address, "$"), "") & ", Complete Red and Partial Strikethrough"
If font_strike = False And count_strike > 0 Then
If font_strike = False And count_strike = 0 Then
msg = "Sheet: " & sh.Name & ", Cell: " & Join(Split(cell.Address, "$"), "") & ", Complete Red"
If font_color = "red" And count_red <> Len(cell_value) Then
msg = "Sheet: " & sh.Name & ", Cell: " & Join(Split(cell.Address, "$"), "") & ", Partial Red and Complete Strikethrough"
msg = "Sheet: " & sh.Name & ", Cell: " & Join(Split(cell.Address, "$"), "") & ", Partial Red and Strikethrough"
msg = "Sheet: " & sh.Name & ", Cell: " & Join(Split(cell.Address, "$"), "") & ", Partial Red"
If font_color = "not red" And count_red > 0 Then
If font_color = "not red" And count_red = 0 Then
msg = "Sheet: " & sh.Name & ", Cell: " & Join(Split(cell.Address, "$"), "") & ", Complete Strikethrough"
msg = "Sheet: " & sh.Name & ", Cell: " & Join(Split(cell.Address, "$"), "") & ", Partial Strikethrough"
Next sh
wb.Close
Sub updateReport(sh_name As String, msg As String)
Set active_wb = ThisWorkbook
Dim check_sheet As Boolean
check_sheet = False
Dim i As Integer
For i = 1 To active_wb.Sheets.count
If active_wb.Sheets(i).Name = sh_name Then
check_sheet = True
Dim lastRow As Integer
If check_sheet = False Then
active_wb.Sheets.Add.Name = sh_name
Set ws = active_wb.Sheets(sh_name)
ws.Cells(1, 1).Value = msg
If check_sheet = True Then
Set ews = active_wb.Sheets(sh_name)
lastRow = ews.Cells(Rows.count, 1).End(xlUp).Row
ews.Cells(lastRow + 1, 1).Value = msg
active_wb.Sheets(sh_name).Cells(1, 1).EntireColumn.AutoFit
