[Solved] Static Range within VB script
Is it possible to define Static Range of certain values inside the VB Script;
Example
Dim Rng as range
Set Rng = [0,10,20,30,40,50,60,70,80,90,100]
Means instead of setting range location from the sheet, giving fix vales
Example
Dim Rng as range
Hello Mfaisal
Thanks for reaching out and posting your issue. In VBScript, you cannot directly define a static range of values like an array using the range object. The range object in VBScript is typically used to represent a cell or a range of cells in an Excel worksheet.
If you want to create an array with specific values in VBScript, you can use the Array Literal notation to define an array with fixed values.
Sub Test()
    Dim Rng As Variant
    Rng = Array(0, 10, 20, 30, 40, 50, 60, 70, 80, 90, 100)
    Debug.Print Rng(1)
In the code above, an array named Rng is declared with a size of 10. Later, Each element of the array is assigned a specific value. Keep in mind that VBScript arrays are Zero-based. The first element is accessed using an index of 0, the second element with an index of 1, and so on.
I hope this will achieve your goal. Feel free to contact us again with any other inquiries or concerns.
