Sub MoveDataBasedCriteria()
Dim wsPI As Worksheet
Dim wsREM As Worksheet
Dim wsTIRE As Worksheet
Dim wsBAJA As Worksheet
Dim wsCBU As Worksheet
Set wsPI = ThisWorkbook.Sheets("PIVOT")
Set wsREM = ThisWorkbook.Sheets("REM")
Set wsTIRE = ThisWorkbook.Sheets("TIRE")
Set wsBAJA = ThisWorkbook.Sheets("BAJA")
Set wsCBU = ThisWorkbook.Sheets("CBU")
Dim tempLastRow As Long
Dim lastCol As Long
Dim currentCol As Long
Dim i, j, k As Long
lastRow = wsPI.Cells(wsPI.Rows.Count, "C").End(xlUp).Row
Dim piNo As String
Dim invoiceNo As String
Dim seriNo As String
Dim sumPIB As Double
For i = 2 To lastRow
If wsPI.Range("A" & i).Value <> "" Then
piNo = wsPI.Range("A" & i).Value
If wsPI.Range("B" & i).Value <> "" Then
invoiceNo = wsPI.Range("B" & i).Value
seriNo = wsPI.Range("C" & i).Value
sumPIB = wsPI.Range("D" & i).Value
If piNo = "04.PI-05.24.0254" Then
lastCol = wsBAJA.Cells(2, wsBAJA.Columns.Count).End(xlToLeft).Column
tempLastRow = wsBAJA.Cells(wsBAJA.Rows.Count, "B").End(xlUp).Row
If lastCol > 4 Then
For k = 5 To lastCol
If wsBAJA.Cells(2, k).Value = invoiceNo Then
currentCol = k
currentCol = k + 1
Next k
wsBAJA.Cells(2, currentCol).Value = invoiceNo
wsBAJA.Cells(2, lastCol + 1).Value = invoiceNo
currentCol = lastCol + 1
For j = 3 To tempLastRow
If wsBAJA.Cells(j, 2).Value = seriNo Then
wsBAJA.Cells(j, currentCol).Value = sumPIB
Next j
ElseIf piNo = "04.PI-66.23.0071" Then
lastCol = wsTIRE.Cells(2, wsTIRE.Columns.Count).End(xlToLeft).Column
tempLastRow = wsTIRE.Cells(wsTIRE.Rows.Count, "B").End(xlUp).Row
If lastCol > 4 Then
If wsTIRE.Cells(2, k).Value = invoiceNo Then
currentCol = k
currentCol = k + 1
Next k
wsTIRE.Cells(2, currentCol).Value = invoiceNo
wsTIRE.Cells(2, lastCol + 1).Value = invoiceNo
If wsTIRE.Cells(j, 2).Value = seriNo Then
wsTIRE.Cells(j, currentCol).Value = sumPIB
Next j
ElseIf piNo = "04.SK-33.24.0027" Then
lastCol = wsREM.Cells(2, wsREM.Columns.Count).End(xlToLeft).Column
tempLastRow = wsREM.Cells(wsREM.Rows.Count, "B").End(xlUp).Row
If lastCol > 4 Then
If wsREM.Cells(2, k).Value = invoiceNo Then
currentCol = k
currentCol = k + 1
Next k
wsREM.Cells(2, currentCol).Value = invoiceNo
wsREM.Cells(2, lastCol + 1).Value = invoiceNo
If wsREM.Cells(j, 2).Value = seriNo Then
wsREM.Cells(j, currentCol).Value = sumPIB
Next j
ElseIf piNo = "04.SK-31.24.0040" Then
lastCol = wsCBU.Cells(2, wsCBU.Columns.Count).End(xlToLeft).Column
tempLastRow = wsCBU.Cells(wsCBU.Rows.Count, "B").End(xlUp).Row
If lastCol > 4 Then
If wsCBU.Cells(2, k).Value = invoiceNo Then
currentCol = k
currentCol = k + 1
Next k
wsCBU.Cells(2, currentCol).Value = invoiceNo
wsCBU.Cells(2, lastCol + 1).Value = invoiceNo
If wsCBU.Cells(j, 2).Value = seriNo Then
wsCBU.Cells(j, currentCol).Value = sumPIB
Next j
