Dumi_Bogdan
Hi, can I please have your help to check this code?
My problem is that when it is supposed to save the file, instead of picking up the specific folder path I added in the VBA, it saves the file in the last folder/directory that I have opened, and then I have to locate it in the folders I accessed in the last hour
Many thanks in advance.
Sub SUBSaveNewStatement()
' Newstatement1 Macro
' copy and save to new file for a new account statement.
Range("A1").Select
Range(Selection, Selection.End(xlDown)).Select
Range(Selection, Selection.End(xlToRight)).Select
Selection.Copy
Workbooks.Add
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks _
:=False, Transpose:=False
Selection.PasteSpecial Paste:=xlPasteFormats, Operation:=xlNone, _
SkipBlanks:=False, Transpose:=False
Application.CutCopyMode = False
'Set the output path and file name
outputPath = "C:\Users\bdumitrascu\OneDrive - PTC\Documents\Account statements"
CustomerName = Range("B2").Value
CustomerNumber = Range("C2").Value
CustomerSite = Range("E2").Value
outputFileName = CustomerName & " - " & CustomerNumber & " - " & CustomerSite & " - Updated Statement - " & Format(Date, "dd-MMM-yyyy") & ".xlsx"
ActiveWorkbook.SaveAs filename:=outputFileName, FileFormat:=xlOpenXMLWorkbook, CreateBackup:=False
Sub SvMe()
'Saves filename
Dim newFile As String, outputFileName As String
'Change the date format to whatever you'd like, but make sure it's in quotes
' Change directory to suit your PC, including USER NAME
ChDir _
Range("A1").Select
Selection.Copy
Workbooks.Add
Sub SvMe()
'Saves filename
ChDir _
