[Solved] weight loss graph
pdo
I created a weight loss graph but on the weight column it keeps going from measured weight lbs to zero lbs and the chart is very flat, how can I change the weight column to go from measured weight to goal weight instead of measured weight to zero lbs?
To adjust your weight loss chart, you must change the y-axis values from going down to zero to reaching your goal weight. Here’s how:
  1. First, set up a new column for your Goal Weight next to your Measured Weight column.
  2. Enter your goal weight in each row of this new column.
  3. In your chart, add the Goal Weight column as a series so the chart shows a line from your current weight towards the goal instead of down to zero.
This should create a more accurate visualization of your progress towards your goal weight. Let me know if you need any more help!
  • Like
Reactions: pdo
