[Solved] مناشدة لجميع الاعضاء ان تردو على سوالي
السلام عليكم دكتور
لوسمحت ممكن مساعدتك بطريقة ممتازة لربط الخلايا المتفرقة من صفحة كاملة بملف
مع ملف ثاني بالعمود C3
بحيث لي بيانات بشكل يومي
وعندما تدخل هذه البيانات بملف الاول
يخرج ينتج اجمالي
اشتي هذا الجمالي ينتقل للملف الثاني بالعمود C3 حسب التاريخ التسلسلي
السلام عليكم دكتور
يخرج ينتج اجمالي
Dear محمد البني,
Thanks for reaching us. I understand that you want to link cells from a full page in a file and calculate the total value in column C of another file for corresponding dates.
To demonstrate this problem, I have taken the following dataset in Sheet2 of Book1 workbook. It contains a date and corresponding 7 values for which I will calculate the total value. I will enter new sequential dates and corresponding values here as well.
K02qa-l405IdoxKKQ-NBQJmjO16b-I4Wo0R_eckZBmhyGUyyC6XskJDb6DvlYyFrTP3AlH_IwOd8uxmD-JI66QdAMOeDH2MqzfufiVmU8v_lrrf9tV09IELpBAo7MwBOhgHx29ZM250NOD3PYQpQTCg
In another workbook named Book3, I have the following dataset where I have sequential dates. I will use a formula to calculate the total values whenever a date and corresponding values are entered in Book1.
-g1PF4jZB-6__UBTelv5KDExiBv0B7QnvddSgnylZ2YMT2v_PJ7vEj4SWMTh0CaIuGsi4id4zEK54FJEyDxxoLH49gSRVphsZxMVbRah_8yGNFFYotIe0ruvejrjcDiGO9G29AKpya9fFQ-e0masu3A
For that, insert the following formula in cell C3 of the data range in Book3 >> copy the formula to below cells using the Fill Handle tool.
=IF([Book1]Sheet2!B13<>"",SUM([Book1]Sheet2!C13:I13),"")
yNDgVKNz6wvHeq_EoUTnPE6aQTdObbcOvyEOkRxdhV8DOhP6x5rkzzz8qkmEiVKHbsV8yVco1ExVIq6XPDkH4E0c6c-jpTGV-o7kZ1fLMFrbBBT6xt4ozT2NejW_LDd4CY9LQiav3URXpUFJywZ51mM
Now, enter today’s date and corresponding values in Sheet2 of Book1.
JZWZgdSuiIRUA_hnsuXdmOdLkmJqF3GiK__Djl1C_bC556VUMwt4lvSesW0NyP7_L2DIlzqMB9Qwp70-dp_J3dAasJFJeX3zlrYirjYivZZ5n3tLpXkQtrNtNwhOttp-XVvOrr40JeG617QXBDpd-UQ
The required output i.e. total value will automatically appear in the Book3 workbook.
usIbkPDnJNxcWyyp-a_r2QOPbuAV3ZwSAJ-Dp4-3HUmaWVj9aks1w5mJUD7c7ANOAqFNTqElM1tgtFl_k1qFiWVRx2v87qvCydv28tzsGfS_E_lvMXY01n5rBQTf9uUVAKqabu5MXVqlggyJCALzZH8
I hope this will provide you with an idea of how to solve your problem. To get the exact solution, please share the corresponding workbooks. Let us know your feedback.
Ehunt256
