Barcode Check out from an inventory
Private Sub CommandButton1_Click()
Dim sn As String
Dim wsLog As Worksheet
Dim currentTime As String
Set wsLog = ThisWorkbook.Sheets("Log")
sn = wsLog.Range("C1").Value ' Scan input cell
currentTime = Format(Now, "mm/dd/yyyy hh:mm:ss AM/PM")
If sn = "" Then
MsgBox "Please scan a barcode."
' Check if item was already scanned out
Dim foundRow As Long
foundRow = 0
For i = wsLog.Cells(wsLog.Rows.Count, "B").End(xlUp).Row To 3 Step -1
If wsLog.Cells(i, 2).Value = sn Then
foundRow = i
If foundRow > 0 And wsLog.Cells(foundRow, 4).Value = "" Then
' Log Check-In
wsLog.Cells(foundRow, 4).Value = currentTime
wsLog.Cells(foundRow, 5).Formula = "=D" & foundRow & "-C" & foundRow
MsgBox "Checked IN successfully!"
' Log Check-Out
lastRow = wsLog.Cells(wsLog.Rows.Count, "B").End(xlUp).Row + 1
wsLog.Cells(lastRow, 2).Value = sn
wsLog.Cells(lastRow, 3).Value = currentTime
MsgBox "Checked OUT successfully!"
wsLog.Range("C1").Value = "" ' Clear scan box
Here's what I used so far now I changed B2 to C1 to put it in the space I wished
Hello Ehunt256,
You're doing an amazing job pushing through each challenge, and your persistence is really paying off! Let’s walk through your three key requests and update your macro accordingly so you can finish strong
    Dim sn As String
    Dim wsInventory As Worksheet
    Dim invRow As Long
    Dim found As Boolean
    Dim i As Long, j As Long
    Set wsInventory = ThisWorkbook.Sheets("Inventory")
    If sn = "" Then
        MsgBox "Please scan a barcode.", vbExclamation
    ' Search SN in Inventory Sheet Columns B, C, D
    found = False
    For i = 2 To wsInventory.Cells(wsInventory.Rows.Count, "B").End(xlUp).Row
        For j = 2 To 4 ' Columns B to D (2 to 4)
            If Trim(wsInventory.Cells(i, j).Value) = Trim(sn) Then
                found = True
                invRow = i
        Next j
        If found Then Exit For
    If Not found Then
        MsgBox "❌ This Serial Number was NOT found in Inventory.", vbCritical
    ' Check if item was already OUT in Log (look for last unmatched OUT entry)
    Dim scanFoundRow As Long
    scanFoundRow = 0
    For i = wsLog.Cells(wsLog.Rows.Count, "B").End(xlUp).Row To 2 Step -1
        If wsLog.Cells(i, 2).Value = sn And wsLog.Cells(i, 4).Value = "" Then
            scanFoundRow = i
    If scanFoundRow > 0 Then
        ' Log Check-IN
        wsLog.Cells(scanFoundRow, 4).Value = currentTime
        wsLog.Cells(scanFoundRow, 5).Formula = "=D" & scanFoundRow & "-C" & scanFoundRow
        MsgBox "Checked IN successfully!", vbInformation
        ' Log Check-OUT
        MsgBox "📦 Checked OUT successfully!", vbInformation
    ' Clear Scan Input
What This Code Now Does:
  • Scans the Inventory sheet (Columns B to D) for a match.
  • If not found, it shows a “Not Found” message and skips logging.
  • If found, it logs:
    • Check-OUT first (by default).
    • Check-IN if that SN already has an OUT entry without a matching IN.
  • Clears the scan input after every action.
Tips for Final Touches:
  • Make sure your Inventory sheet has values in columns B, C, or D starting from row 2.
  • Save your workbook as .xlsm to retain macros.
  • You can later expand this to update inventory status or quantity if needed.
Hello Ehunt256,
I try to be persistent enough to get and understanding of what I'm learning and I'm sorry for all the confusion trying to explain what I wanted to learn, thank you for your patience to helping understand this better.
    Dim sn As String
    Dim invRow As Long
    If sn = "" Then
    found = False
                found = True
                invRow = i
        Next j
    If Not found Then
    scanFoundRow = 0
            scanFoundRow = i
        ' Log Check-IN
        ' Log Check-OUT
    ' Clear Scan Input
Yep, I think this covers it if there any issues I will chalk them to user error and attempt to correct.
as for learning VBA I still got a ways to go to fully learn it, BUT I see the practical applications and it's worth learning, here's hoping I can master Excel in the future.
Runtime error 13 type mismatch it has something to do with this line. Any ideas?
Ok this seems to fix it I had to internet solve this one
If Trim(CStr(wsInventory.Cells(i, j).Value)) = Trim(sn) Then
Hello Ehunt256,
Yes, you found the correct solution!
The Run-time error 13: Type mismatch can occur because one or more cells in the Inventory range may contain a value that Trim() cannot handle directly, such as a number or another non-text value.
Your revised line:
is a good fix. CStr() converts the cell value to a string before Trim() processes it, so the comparison works more reliably when your Inventory contains a mixture of text and numeric values.
So, I would keep the CStr() version in your code.
And nice work troubleshooting this one yourself! Finding the cause of errors and testing possible fixes is one of the best ways to become more comfortable with VBA.
dmplaygamesio
