Hello Jululian,Dear All
may i kindly request you to please help me in excel formula as per attached timetable formula
I would be grateful for any assistance you provided
regards
Dear Mrs. ShamimaritaHello Jululian,
I updated the Morning Overtime, Evening Overtime, and Late Morning formulas.
Morning Overtime: =IFNA(IF(C2<TIME(12,0,0), TIME(12,0,0)-C2, MAX(0, TIME(12,0,0)-C2-TIME(0,5,0))),"")
Evening Overtime: =IF(D2 < C2, D2 + 1 - TIME(22,0,0), IF(D2 > TIME(22,0,0), D2 - TIME(22,0,0), 0))
Late Morning: =IF(C2>TIME(12,0,0), C2-TIME(12,0,0),"00:00")
To get the desired Time format follow the steps below:
Press, CTRL+1 to get the Format Cells dialog box,
Then, select Custom >> types mm:ss for minute:second format. If you want to show hour:minute:second format use this h:mm:ss
Here is the Excel File:
Hello Jululian,Dear Mrs. Shamimarita
First of all, I would like to thank you for your time and interest in considering my inquiry. I have some notes marked in yellow if your time allows you to have a look
Your help with this issue is greatly appreciated and has had a significant impact. thank youHello Jululian,
The formula is working fine. To match your desired output I used mm:ss time format earlier. Here, I used hh:mm time format now.
Please change the time format only.
Here is the updated Excel File:
You are most welcome. Thanks for your appreciation.Your help with this issue is greatly appreciated and has had a significant impact. thank you
