[Solved] Compare two sheets and find missing and Duplicate to another sheet
john7777
I would like to compare two sheets and copy result to another sheet as per the attached file with the help of macro.
Hoping your help regarding this matter.
thanks for every previous help.
Hello John,
Thank you for sharing your experience with us. Today, I am going to help you write a VBA code that compares the value of 2 sheets and finds the missing and duplicate values in another sheet.
Before going there, read the below article to learn 7 suitable methods to get the missing data after comparison. You will also get an idea of what we are actually doing:
See what you looking for? If not then I have an alternative VBA code that will be more suitable in your case.
Sub MacroCompare()
'ExcelDemy Product
    Dim ws1 As Worksheet, ws2 As Worksheet, wsResult As Worksheet
    Dim dict1 As Object, dict2 As Object
    Set dict1 = CreateObject("Scripting.Dictionary")
    Set dict2 = CreateObject("Scripting.Dictionary")
    Dim key As Variant
    ' Set the worksheets you want to compare
    Set ws1 = ThisWorkbook.Sheets("Sheet1")
    Set ws2 = ThisWorkbook.Sheets("Sheet2")
    ' Create a new worksheet to store the results
    Set wsResult = ThisWorkbook.Sheets.Add
    wsResult.Name = "See Result"
    ' Initialize collections to store missing and duplicate values
    Dim missingColumn1 As Collection, missingColumn2 As Collection
    Set missingColumn1 = New Collection
    Set missingColumn2 = New Collection
    Dim duplicateColumn As Collection
    Set duplicateColumn = New Collection
    ' Loop through the first sheet and add values to dict1
    For Each cell In ws1.Range("B1:B" & ws1.Cells(Rows.Count, "B").End(xlUp).Row)
        key = cell.Value
        If Not dict1.Exists(key) Then
            dict1.Add key, 1
            dict1(key) = dict1(key) + 1
    ' Loop through the second sheet and add values to dict2
    For Each cell In ws2.Range("A1:A" & ws2.Cells(Rows.Count, "A").End(xlUp).Row)
        key = cell.Value
        If Not dict2.Exists(key) Then
            dict2.Add key, 1
            dict2(key) = dict2(key) + 1
    For Each key In dict1.Keys
            missingColumn1.Add key
    Next key
    For Each key In dict2.Keys
            missingColumn2.Add key
    Next key
    ' Find duplicate values in both sheets and add them to duplicateColumn
        If dict2.Exists(key) Then
            Dim count1 As Long, count2 As Long
            count1 = dict1(key)
            count2 = dict2(key)
            If count1 > 0 And count2 > 0 Then
                Dim minCount As Long
                minCount = WorksheetFunction.Min(count1, count2)
                For i = 1 To minCount
                    duplicateColumn.Add key
    Next key
    ' Write missing values in Sheet2 to the result sheet
    wsResult.Cells(1, 1).Value = "Missing Values in Sheet2"
    Dim rowIndex As Long
    rowIndex = 2
    For Each key In missingColumn1
        wsResult.Cells(rowIndex, 1).Value = key
        rowIndex = rowIndex + 1
    Next key
    ' Write missing values in Sheet1 to the result sheet
    wsResult.Cells(1, 2).Value = "Missing Values in Sheet1"
    rowIndex = 2
    For Each key In missingColumn2
        wsResult.Cells(rowIndex, 2).Value = key
    Next key
    ' Write duplicate values to the result sheet under "Duplicate Values" column
    wsResult.Cells(1, 3).Value = "Duplicate Values"
    rowIndex = 2
    For Each key In duplicateColumn
        wsResult.Cells(rowIndex, 3).Value = key
    Next key
    ' Clean up
    Set dict1 = Nothing
    Set dict2 = Nothing
    Set missingColumn1 = Nothing
    Set missingColumn2 = Nothing
    Set duplicateColumn = Nothing
    Set ws1 = Nothing
    Set ws2 = Nothing
    Set wsResult = Nothing
    MsgBox "Comparison completed!", vbInformation
The MacroCompare compares data between Sheet1 and Sheet2 and presents the results in a new sheet. It uses two scripting dictionaries (dict1 and dict2) to keep track of unique values in each sheet. Finally, it creates a new sheet See Result to display the results and provides a completion message with an MsgBox like below.
I have attached my working workbook. Please practice and let us know if it works for you.
Thank you for your kind help and tutorial link you you given. I checked that link and very helpful.
The given VBA, did it compare B and C column ie. Item and quantity. If sheet1 Item and Quantity is matching Sheet2 that is not Duplicate. That item may differ.
If we want to compare with A,B,C column whether it has data on then how to change the code.
Both sheet's B and C column matching then it is not Duplicate.
Hello John,
Thanks for your feedback! Yes, you got that right. The previous code compared only the items of the 2 sheets as I thought. If you want to change the comparison ranges, we can modify the code for you.
Can you specify your requirements one more time? For instances:
  • Do we get the missing values based on Sheet1 or Sheet2? i.e. There are data in Sheet1 but not in Sheet2 or vice versa?
  • How do you want to see the output in the new sheet? Is it in a single column or multiple separate columns?
It would be more clear if you could create an expected output sheet based on your current data manually and share the workbook file with us.
Again, thank you for your appreciation and feedback. Best Regards!
Hello John,
Thanks for your reply and help.
We need to get missing values based on Sheet1, ie Data in shee1 but not in Sheet2, and duplicate from both Sheets
Output is same as in result sheet (See Result) in single sheet with Date , item quantity (A,B,C ) column ie Missing Value in Sheet2, Duplicate Values in both sheet
Hello John,
Thanks for your thorough explanation. I think this is the code you want:
Option Explicit
Sub CompareData()
    Dim wbk As Workbook
    Dim wshMyData As Worksheet, wshBrokersData As Worksheet, wshResult As Worksheet
    Dim i As Integer, j As Integer, k As Integer
    Dim sTmp As String
    Dim key As Variant
    On Error Resume Next
    Set wbk = ThisWorkbook
    Set wshResult = wbk.Worksheets.Add(After:=wbk.Sheets(wbk.Sheets.Count))
    wshResult.Name = "Result"
    On Error GoTo Err_CompareData
    Set wshMyData = wbk.Worksheets("Sheet1")
    Set wshBrokersData = wbk.Worksheets("Sheet2")
    ' Create dictionaries to store data from both sheets
    ' Populate dict1 with data from Sheet1
    For Each cell In wshMyData.Range("A1:C275")
        key = cell.Value
    ' Populate dict2 with data from Sheet2
    For Each cell In wshBrokersData.Range("A1:C275")
        key = cell.Value
    ' Write missing values from Sheet2 to Result sheet in columns A, B, C
    k = 1
            k = k + 1
            wshResult.Cells(k, 1).Value = key
            wshResult.Cells(k, 2).Value = key.Offset(0, 1).Value
            wshResult.Cells(k, 3).Value = key.Offset(0, 2).Value
    Next key
    ' Write duplicate values to Result sheet in columns D, E, F
    k = 1
            k = k + 1
            wshResult.Cells(k, 4).Value = key
            wshResult.Cells(k, 5).Value = key.Offset(0, 1).Value
            wshResult.Cells(k, 6).Value = key.Offset(0, 2).Value
    Next key
    ' Autofit columns
    wshResult.Columns.AutoFit
Exit_CompareData:
    Set wshMyData = Nothing
    Set wshBrokersData = Nothing
    Set wshResult = Nothing
    Set wbk = Nothing
    Set dict1 = Nothing
    Set dict2 = Nothing
Err_CompareData:
    MsgBox Err.Description, vbExclamation, Err.Number
    Resume Exit_CompareData
This code will return the missing values of Sheet2 in Column A of Result sheet and duplicate values in Column B of the same sheet.
I am attaching the workbook. Let me know if you need further assistance. Best Regards!
Hi John
I need to filter records based on a value.
Records to be filter are around 200 and sum of few records will bring required total value.
Example data:
2966.84
217.36
7670.51
19167.4
9357.28
2646.18
1412.78
108.68
434.7
I need to filter out records from above list for a value of 1956.16 which is total of last three records.
Any formula or tick to do this.
An early response is appreciated.
Hello John,
Option Explicit
Sub CompareData()
    Dim wbk As Workbook
    Dim sTmp As String
    Dim key As Variant
        key = cell.Value
        key = cell.Value
    k = 1
            k = k + 1
    Next key
    k = 1
            k = k + 1
    Next key
    ' Autofit columns
Exit_CompareData:
    Set wbk = Nothing
    Set dict1 = Nothing
    Set dict2 = Nothing
Err_CompareData:
Thankyou for reply and help.
1st The code which you given not working, I download the attached file which is working but duplicates value of both sheet1 and Sheet2 comes together. Also Date columns of Duplicate value comes between missing items Column A. I would like to have the report as the attached file, can you help me to provide a report as per the attached format. Hoping you may help regarding this matter.
Thanks in advance
Hello John,
I apologize for the misunderstanding. It is now clear that you want the duplicate values of each sheet on their respective sheets. Thanks for your expected outcome sheet.
You can try this code instead:
Option Explicit
Sub Compare_Without_Formulas()
'An ExcelDemy Product
    Dim ws1 As Worksheet, ws2 As Worksheet, ws3 As Worksheet
    Set ws1 = Worksheets("Sheet1")          '<-- Change sheet names to suit
    Set ws2 = Worksheets("Sheet2")
    Set ws3 = Worksheets("Expected Result")
    Dim LRow1 As Long, LRow2 As Long
    Dim i As Long, j As Long
    Dim cellValue As Variant
    Dim found As Boolean
    Dim missingValues As String
    Dim duplicateValuesSheet1 As String, duplicateValuesSheet2 As String
    Dim dictSheet1 As Object, dictSheet2 As Object
    Dim outputRow As Long
    ' Clear existing data in the result sheet
    ws3.Cells.Clear
    ' Find the last rows in Sheet1 and Sheet2
    LRow1 = ws1.Cells(ws1.Rows.Count, "B").End(xlUp).Row
    LRow2 = ws2.Cells(ws2.Rows.Count, "A").End(xlUp).Row
    ' Initialize the output row
    outputRow = 3
    ' Check for missing values in Sheet1 but not in Sheet2
    For i = 2 To LRow1
        cellValue = ws1.Cells(i, 2).Value
        found = False
        For j = 1 To LRow2
            If ws2.Cells(j, 1).Value = cellValue Then
                found = True
        Next j
        If Not found Then
            ws3.Cells(outputRow, 2).Value = cellValue
            outputRow = outputRow + 1
    If outputRow = 3 Then
        ws3.Cells(3, 2).Value = "no missing values found"
    ' Check for duplicates in Sheet1
    outputRow = 3
    Set dictSheet1 = CreateObject("Scripting.Dictionary")
    For i = 2 To LRow1
        If dictSheet1.Exists(cellValue) Then
            ws3.Cells(outputRow, 5).Value = cellValue
            dictSheet1(cellValue) = 1
        ws3.Cells(3, 5).Value = "no duplicates found"
    ' Check for duplicates in Sheet2
    outputRow = 3
    Set dictSheet2 = CreateObject("Scripting.Dictionary")
    For i = 1 To LRow2
        cellValue = ws2.Cells(i, 1).Value
        If dictSheet2.Exists(cellValue) Then
            ws3.Cells(outputRow, 8).Value = cellValue
            dictSheet2(cellValue) = 1
        ws3.Cells(3, 8).Value = "no duplicates found"
Note: Make sure your file has Sheet1, Sheet2 and Expected Result sheets present. Also, the code output varies from your expected output a little.
I am attaching the workbook. Please, do not hesitate if you need any additional assistance. Thank you for staying in touch. I believe we will get through this problem soon.
Regards.
Hello John,
This is an alternative VBA code to find the missing and duplicate data. The code also puts column headers in the output sheet as you asked.
Sub FindMissingDuplicates()
    Dim sourceSheet As Worksheet, targetSheet As Worksheet, resultSheet As Worksheet
    Set sourceSheet = Worksheets("Sheet1")        'Change sheet names if required here
    Set targetSheet = Worksheets("Sheet2")
    Set resultSheet = Worksheets("Expected Result")
    ' Add headers in the output sheet
    resultSheet.Range("A2").Value = "Date"
    resultSheet.Range("B2").Value = "Item"
    resultSheet.Range("C2").Value = "Quantity"
    resultSheet.Range("D2").Value = "Date"
    resultSheet.Range("E2").Value = "Item"
    resultSheet.Range("F2").Value = "Quantity"
    resultSheet.Range("G2").Value = "Date"
    resultSheet.Range("H2").Value = "Item"
    resultSheet.Range("I2").Value = "Quantity"
    resultSheet.Range("A1:C1").Merge
    resultSheet.Range("A1").Value = "Missing Values in Sheet2"
    resultSheet.Range("D1:F1").Merge
    resultSheet.Range("D1").Value = "Duplicate Values in Sheet1"
    resultSheet.Range("G1:I1").Merge
    resultSheet.Range("G1").Value = "Duplicate Values in Sheet2"
    ' Clear existing contents in output columns
    With resultSheet
        .Range("B3:B" & Application.Max(.Cells(.Rows.Count, "B").End(xlUp).Row, 3)).ClearContents
        .Range("E3:E" & Application.Max(.Cells(.Rows.Count, "E").End(xlUp).Row, 3)).ClearContents
        .Range("H3:H" & Application.Max(.Cells(.Rows.Count, "H").End(xlUp).Row, 3)).ClearContents
    Dim sourceData, targetData, missingData
    sourceData = sourceSheet.Range("B1", sourceSheet.Cells(Rows.Count, "B").End(xlUp))
    targetData = targetSheet.Range("A1", targetSheet.Cells(Rows.Count, "A").End(xlUp))
    ReDim missingData(1 To UBound(sourceData, 1), 1 To 1)
    With CreateObject("scripting.dictionary")
        .comparemode = 1
        For i = 1 To UBound(sourceData, 1)
            .Item(sourceData(i, 1)) = Empty
        For i = 1 To UBound(targetData, 1)
            If Not .exists(targetData(i, 1)) Then
                j = j + 1
                missingData(j, 1) = targetData(i, 1)
    resultSheet.Range("B3").Resize(j).Value = missingData
    Dim lastRow As Long, criteriaRange As Range, copyToRange As Range
    lastRow = sourceSheet.Cells(Rows.Count, "B").End(xlUp).Row
    Set copyToRange = resultSheet.Range("E3")
    With sourceSheet.Range("B1:B" & lastRow)
        Set criteriaRange = .Offset(, .Columns.Count + 1).Resize(2, 1)
        criteriaRange.Cells(2, 1).Formula = "=COUNTIF(B2:B" & lastRow & ",B2)>1"
        .AdvancedFilter xlFilterCopy, criteriaRange, copyToRange, 1
        sourceSheet.Rows(1).Delete
    criteriaRange.Cells(1).Resize(2, 1).ClearContents
    resultSheet.Range("E3").Delete xlUp
    lastRow = targetSheet.Cells(Rows.Count, "A").End(xlUp).Row
    Set copyToRange = resultSheet.Range("H3")
    With targetSheet.Range("A1:A" & lastRow)
        criteriaRange.Cells(2, 1).Formula = "=COUNTIF(A2:A" & lastRow & ",A2)>1"
        targetSheet.Rows(1).Delete
    resultSheet.Range("H3").Delete xlUp
After you have found the missing and duplicate values, these blogs will help you to deal with them:
Let me know if it works for you. Cheers!
Hello John,
    With resultSheet
        .comparemode = 1
                j = j + 1
Thanks for all the help you provide regarding this question.
As per the report , we mentioned Date, Item , Quantity for each reports,
ie Missing Values in Sheet2, Duplicate Value in Sheet1, Duplicate values in Sheet2.
Can we show Date and Item for each report in report sheet if there is date and quantity in source sheets. Also it will be good if you can show the row number of source for each item.
Thank you if you can do it for me
Thank you for your words of appreciation!
Do you want to list every occurrence of the duplicated item from the source sheet? The reason I ask is that using Hercules Sparx 2.0 RF 24" Black as an example, there are 3 instances of that item on sheet 1 - only the second one has a date, the first and third instances have quantities of 6, the second has a quantity of 4. Which instance would you want, or all three?
And, how exactly do you want to show that? In another column on the expected results sheet?
For now, you can try this code for the column order which I thought a bit logical:
Option Explicit
Sub Compare2Sheets()
    Application.ScreenUpdating = False
    Dim ws1 As Worksheet, ws2 As Worksheet, ws3 As Worksheet, LRow As Long
    If ws1.AutoFilterMode Then ws1.AutoFilter.ShowAllData
    'Clear any existing results
    LRow = Application.Max(ws3.Cells.Find("*", , xlFormulas, , 1, 2).Row, 3)
    ws3.Range("A3:Z" & LRow).ClearContents
    'Get the data missing on sheet 2
    Dim a, b, c, d, x
    a = ws1.Range("B1", ws1.Cells(Rows.Count, "B").End(xlUp))
    b = ws2.Range("A1", ws2.Cells(Rows.Count, "A").End(xlUp))
    ReDim c(1 To UBound(a, 1), 1 To 1)
        .comparemode = 1
        For i = 1 To UBound(a, 1)
            .Item(a(i, 1)) = Empty
        For i = 1 To UBound(b, 1)
            If Not .exists(b(i, 1)) Then
                j = j + 1
                c(j, 1) = b(i, 1)
    ws3.Range("A3").Resize(j).Value = c
    'Get the duplicates on sheet 1
    With ws1
        .Activate
        .Rows(1).Insert
        .Range("A1:E1").Value = Array("Date", "Item", "Qty", "Row", "Count")
    LRow = ws1.Cells(Rows.Count, "B").End(xlUp).Row
    With ws1.Range("D2:D" & LRow)
        .Value = Evaluate("Row(" & .Address(, , , 1) & ")")
    With ws1.Range("E2:E" & LRow)
        .Value = Evaluate("Countif(B2:B" & LRow & "," & .Offset(, -3).Address(, , , 1) & ")")
    With ws1.Range("A1").CurrentRegion
        .AutoFilter 5, ">1"
        If .SpecialCells(xlCellTypeVisible).Address <> .Rows(1).Address Then
            .Offset(1).Resize(, 4).Copy ws3.Range("D3")
        .AutoFilter
        .Range("D:E").ClearContents
        .Rows(1).Delete
    'Get the duplicates on sheet 2 (if any) and the qty/row on the missing from sheet 2
    With ws2
        .Activate
        .Rows(1).Insert
        .Range("A1:D1").Value = Array("Item", "Qty", "Row", "Count")
    LRow = ws2.Cells(Rows.Count, "A").End(xlUp).Row
    With ws2.Range("C2:C" & LRow)
    With ws2.Range("D2:D" & LRow)
        .Value = Evaluate("Countif(A2:A" & LRow & "," & .Offset(, -3).Address(, , , 1) & ")")
    With ws2.Range("A1").CurrentRegion
        .AutoFilter 4, ">1"
            .Offset(1).Resize(, 3).Copy ws3.Range("H3")
        .AutoFilter
        LRow = Application.Max(ws2.Cells(Rows.Count, "A").End(xlUp).Row, 2)
        d = ws2.Range("A2:D" & LRow)
        x = ws3.Range("A3:C" & ws3.Cells(Rows.Count, "A").End(xlUp).Row)
        For i = 1 To UBound(x, 1)
            For j = LBound(d, 1) To UBound(d, 1)
                If d(j, 1) = x(i, 1) Then x(i, 2) = d(j, 2): x(i, 3) = d(j, 3)
            Next j
        ws3.Range("A3").Resize(UBound(x, 1), 3).Value = x
        .Range("C:D").ClearContents
        .Rows(1).Delete
    Application.Goto ws3.Cells(1), 1
    Application.ScreenUpdating = True
Note: You can erase these lines if the expected result sheet is empty before running the code.
Option Explicit
    Dim a, b, c, d, x
        .comparemode = 1
                j = j + 1
                c(j, 1) = b(i, 1)
    With ws1
        .Activate
        .Rows(1).Insert
        .AutoFilter 5, ">1"
        .AutoFilter
        .Rows(1).Delete
    With ws2
        .Activate
        .Rows(1).Insert
        .AutoFilter 4, ">1"
        .AutoFilter
            Next j
        .Rows(1).Delete
I want every occurrence of the duplicated item with row number, date, quantity.
If this code provide the result like that.
I apologize I am not following you. The code provides the duplicate items with the row number, date, and quantity for both sheets.
Here is an image of the duplicate items of Sheet1.
If you have additional requirements, please share a demo file with your expected results in it. Thank you for your feedback!
The Code which you provide showing some error. I copied and paste it on file. But showing errors. It is not working. Also please tell me it shows all duplicate items as you mentioned on the previous answer regarding Hercules Sparx 2.0 RF 24" Black . Please can you provide file with code. a excel file with new code .
Hello John,
The code returns an error because of these lines:
The code thinks you have existing data in the Expected Result sheet. So, it erases them first and then displays the output. I am guessing the sheet is empty in your case, hence the error. Just delete these lines if you do not want to encounter the error.
Thank you.
Ashish Soni
