Convert between lat/long and UTM
Hi, I'm following the guide posted by LUTFOR RAHMAN SHIMANTO (https://www.exceldemy.com/convert-lat-long-to-utm-excel/) to convert between latitude/longitude and UTMs. Everything works except for the CalculateUTMNorthing function, which returns a VALUE error. Any tips on where I went wrong? Thank you in advance!
Hello Lucas
Thanks for reaching out and sharing your queries. The presented User-defined function for calculating UTM Northing in the article should be compatible with most versions of Excel. If you want more compatibility, consider making a few adjustments: replacing the # symbol (used to denote doubles in some VBA versions) and using the CDbl function.
UPDATED User-defined Function for Calculating UTM Northing:
Function NewCalculateUTMNorthing(latitude As Double, longitude As Double) As Double
    Dim utmZone As Integer
    utmZone = Int((longitude + 180) / 6) + 1
    Dim hemisphere As Integer
    If latitude < 0 Then
        hemisphere = -1
        hemisphere = 1
    Dim CentralMeridian As Double
    CentralMeridian = (utmZone - 1) * 6 - 180 + 3
    Dim ScaleFactor As Double
    ScaleFactor = 0.9996
    Dim EquatorialRadius As Double
    EquatorialRadius = CDbl(6378137)
    Dim EccentricitySquared As Double
    EccentricitySquared = CDbl(0.00669438)
    Dim N As Double
    N = EquatorialRadius / Sqr(1 - EccentricitySquared * Sin(latitude * 3.14159265358979 / 180) ^ 2)
    Dim T As Double
    T = Tan(latitude * 3.14159265358979 / 180) ^ 2
    Dim C As Double
    C = EccentricitySquared * Cos(latitude * 3.14159265358979 / 180) ^ 2
    Dim A As Double
    A = Cos(latitude * 3.14159265358979 / 180) * (longitude - CentralMeridian) * 3.14159265358979 / 180
    Dim M As Double
    M = EquatorialRadius * ((1 - EccentricitySquared / 4 - 3 * EccentricitySquared ^ 2 / 64 - 5 * EccentricitySquared ^ 3 / 256) * latitude * 3.14159265358979 / 180 - (3 * EccentricitySquared / 8 + 3 * EccentricitySquared ^ 2 / 32 + 45 * EccentricitySquared ^ 3 / 1024) * Sin(2 * latitude * 3.14159265358979 / 180) + (15 * EccentricitySquared ^ 2 / 256 + 45 * EccentricitySquared ^ 3 / 1024) * Sin(4 * latitude * 3.14159265358979 / 180) - (35 * EccentricitySquared ^ 3 / 3072) * Sin(6 * latitude * 3.14159265358979 / 180))
    Dim UTMScaleFactor As Double
    UTMScaleFactor = 0.9996
    Dim UTMFalseNorthing As Double
    If hemisphere = 1 Then
        UTMFalseNorthing = 0
        UTMFalseNorthing = 10000000
    Dim UTMNorthing As Double
    UTMNorthing = UTMScaleFactor * (M + N * Tan(latitude * 3.14159265358979 / 180) * (A ^ 2 / 2 + (5 - T + 9 * C + 4 * C ^ 2) * A ^ 4 / 24 + (61 - 58 * T + T ^ 2 + 600 * C - 330 * EccentricitySquared) * A ^ 6 / 720)) + UTMFalseNorthing
    NewCalculateUTMNorthing = CDbl(UTMNorthing)
OUTPUT OVERVIEW:
Updated version of user-defined function for calculating UTM Northing.png​
I am letting you know that the Excel VBA User-defined function for calculating UTM Northing is working perfectly at our end. It has yet to be mentioned that we are using Microsoft 365.
User-defined function for calculating Northing is working at out end.png​
So, use the Updated user-defined function and let us know mentioning which Excel Version you are currently using.
Thank you for the reply! Unfortunately the NewCalculateUTMNorthing function is still producing the same VALUE error message.
I'm using Microsoft Excel 2016 (16.0.5422.1000) MSO (16.0.5422.1000) 32-bit. Is this version too outdated to run this successfully?
The Easting and Zone functions work perfectly.
tylekeobongdamy
