[Solved] Empty space in cell with Code128 function
gsfragaro
Hi,
I'm trying to use the vb code you posted in the article "How to Generate Code 128 Barcode Font for Excel"
In my case not work: When i have a string with two consecutive zeros the code generate a empty character...
Second question: can I use it with a 128C font?
can you help me?
Hi,
can you help me?
Hello GSFRAGARO
Welcome to ExcelDemy Form. Thanks for sharing your problem. You have encountered an issue like you have a string with two consecutive zeros, but the code generates an empty character. In Our machine, the code and font work perfectly fine if we have a string with two consecutive zeros. See the following Image,
Maybe the IDAutomationHc128S.tiff font is the reason behind your problem. Please share your IDAutomationHc128S.tiff file within this thread so that we can investigate properly.
