i am not able to insert pictures via names in merged cells and most of my pics are not fit properly.
also my inserted images not showing in another system please help me. plzz
Hello Vipinpanchal2008
Thanks for reaching out and posting your query. You are unable to insert images using names. Besides, you cannot fit the inserted images within merged cells.
I am delighted to inform you that I have developed an Excel VBA sub-procedure to fulfil your requirements. Unlike the previous solution in another thread, this time, I have defined the cellAddress variable as ranges instead of cells.
I am doing these only for four images. You can only define the desired amount of merged ranges in the code and Run.
Excel VBA Sub-procedure:
Sub InsertAnFitImagesInMergedCells()
    Dim cellAddresses As Variant
    Dim cellAddress As Variant
    Dim imgFile As Variant
    Dim pic As Picture
    Dim mergedWidth As Double
    Dim mergedHeight As Double
    cellAddresses = Array("B5:L29", "B31:L55", "B64:L86", "B88:L112")
    With Application.FileDialog(msoFileDialogFilePicker)
        .Title = "Select Image Files"
        .Filters.Add "Image Files", "*.jpg; *.jpeg; *.png; *.gif; *.bmp", 1
        .AllowMultiSelect = True
        If .Show = -1 Then
            For i = 1 To .SelectedItems.Count
                cellAddress = cellAddresses(i - 1)
                Set cell = ThisWorkbook.Sheets("Snaps").Range(cellAddress)
                mergedWidth = cell.Width
                mergedHeight = cell.Height
                Set pic = cell.Parent.Pictures.Insert(.SelectedItems(i))
                pic.ShapeRange.LockAspectRatio = msoFalse
                pic.Width = mergedWidth
                pic.Height = mergedHeight
                pic.Left = cell.Left
                pic.Top = cell.Top
OUTPUT:
I am also attaching the solution workbook to help you understand better. Stay Blessed.
98winmvcomn
