Dear Jululian,
Thanks for reaching us. I understand that you want to make a value positive or negative based on another cell’s value. To demonstrate your problem, I have taken a similar dataset to yours.
Since you want the positive or negative values in Column
C, I have taken the actual values in Column
B. I have also listed the required options in Column
G to facilitate the formula.
Here, I want to select the options from a drop-down list, so I have used
Data Validation. I selected the range
E5:E9 and selected the
Data Validation option from the
Data tab.
Then, I selected the
List option from the drop-down menu and set the list
Source to
$G$5:$G$6, and pressed the
OK button.
In Cell
E5, I selected an option from the dropdown menu, and In Cell
C5, I inserted the following formula.
=IF(E5=$G$5,B5*(-1),IF(E5=$G$6,B5,""))
The final output after selecting options and dragging the
Fill Handle tool is the following:
The workbook I used is attached below. Let us know your feedback.
