[Solved] Lookup Formula to Find the Weight Based on Criteria
Jululian
Dear All​
May I kindly request you help with lookup formula in excel 2016​
as per attached excel sheet​
Your assistance in this issue is highly appreciated​
I am using excel 2016 at work​
Many Thanks​
  • Book1.xlsx
I solved my issues, but there is still one problem that my column C, the age equal or less than 24, that I did not solve i need your
  • Book1.xlsx
Hello Jululian
It is good to see you again. You wanted to find the weight based on criteria such as height (155 cm) and age (between points), for example, 0 to 24, 25 to 29, etc.
Don't worry! I have developed a complex formula to fulfil your goal. However, I had to modify the heading a bit. I have demonstrated the idea in your given file.
SOLUTION Overview:
Complex Formula (Using INDEX, MATCH, VALUE, MID, RIGHT, IF and ISNUMBER):
=INDEX($C$7:$G$27, MATCH($L$9, $B$7:$B$27, 0), MATCH(1, (VALUE(MID($C$4:$G$4, 12, 2)) <= $M$9) * ($M$9 <= IF(ISNUMBER(VALUE(RIGHT($C$4:$G$4, 2))), VALUE(RIGHT($C$4:$G$4, 2)), 0)), 0))
I hope you have found the formula you were looking for. I have attached the solution workbook; good luck.
  • Book1.xlsx
Hello Jululian
SOLUTION Overview:
Thank you for your support I appreciate your help so much many Thanks
