[Solved] Macro for drop down list.
arc_poojari
Hi
I have database having details of sales done by different sales person. Which i need to circulate to all sales person, however i want to put restriction on them of viewing data of other sales person. My excel sheet works on drop down list .Can i have user based restriction in drop down list.
Hi
Hello Arc Poojari
Thanks for reaching out and posting your queries with such clarity.
Requirement: You have a database with details of sales done by a different salesperson. You want to restrict them from viewing other salespeople's data. Your Excel sheet works on a drop-down list. You asked to implement a user-based restriction in the drop-down list.
The functionalities you mentioned can be developed with the help of Excel Features and Excel VBA. I am delighted to inform you that I have designed an Excel File for your goal.
Overview:
I am also attaching the solution workbook. You have to download the file and unlock it. I will also provide more instructions and necessary codes in the upcoming reply.
Hi
Dear Arc Poojari
Thanks once again for bringing up such an interesting problem. Previously, I have shown you the overview of the whole system. Throughout this reply, I will guide you step-by-step in reaching your goal.
Dataset:
Drop-Down:
Other Sheets:
VBA Code within Drop Down Sheet:
Dim SalesRep1 As String
Dim SalesRep2 As String
Dim SalesRep3 As String
    If Target.Address = "$B$2" And Target.Parent.Name = "Drop Down" Then
        Call displaySalePurchase
Sub displaySalePurchase()
    Dim dSP1 As Worksheet
    Dim dSP2 As Worksheet
    Dim dSP3 As Worksheet
    Dim SP As Worksheet
    Dim DR As Worksheet
    Set dSP1 = ThisWorkbook.Sheets("Sheet1")
    Set dSP2 = ThisWorkbook.Sheets("Sheet2")
    Set dSP3 = ThisWorkbook.Sheets("Sheet3")
    Set SP = ThisWorkbook.Sheets("Sales Data")
    Set DR = ThisWorkbook.Sheets("Drop Down")
    Call FindUniqueNames
    If DR.Range("B2").Value = SalesRep1 Then
        Call OpenProtectedSheet1
        'On Error GoTo ErrorHandler1
        SP.AutoFilterMode = False
        SP.UsedRange.AutoFilter Field:=1, Criteria1:=DR.Range("B2").Value
'ErrorHandler1:
'        Exit Sub
        dSP1.UsedRange.Clear
        SP.UsedRange.SpecialCells(xlCellTypeVisible).Copy
        dSP1.Range("A1").PasteSpecial xlPasteValuesAndNumberFormats
        Call UnhideSheet1
        dSP1.Activate
    ElseIf DR.Range("B2").Value = SalesRep2 Then
        Call OpenProtectedSheet2
 '       On Error GoTo ErrorHandler2
        'ThisWorkbook.Sheets("Sheet2").Visible = xlSheetVisible
'ErrorHandler2:
'        Exit Sub
        dSP2.UsedRange.Clear
        dSP2.Range("A1").PasteSpecial xlPasteValuesAndNumberFormats
        Call UnhideSheet2
        dSP2.Activate
    ElseIf DR.Range("B2").Value = SalesRep3 Then
        Call OpenProtectedSheet3
'        On Error GoTo ErrorHandler3
'ErrorHandler3:
'        Exit Sub
        dSP3.UsedRange.Clear
        dSP3.Range("A1").PasteSpecial xlPasteValuesAndNumberFormats
        Call UnhideSheet3
        dSP3.Activate
Sub FindUniqueNames()
    Dim uniqueNames() As String
    Dim isDuplicate As Boolean
    Dim i As Long, j As Long
    Set ws = ThisWorkbook.Sheets("Sales Data")
    lastRow = ws.Cells(ws.Rows.Count, "A").End(xlUp).Row
    ReDim uniqueNames(1 To lastRow - 1)
    j = 0
    For i = 2 To lastRow
        Dim currentName As String
        currentName = Trim(ws.Cells(i, "A").Value)
        isDuplicate = False
        Dim k As Long
        For k = 1 To j
            If uniqueNames(k) = currentName Then
                isDuplicate = True
        Next k
        If Not isDuplicate Then
            j = j + 1
            uniqueNames(j) = currentName
    ReDim Preserve uniqueNames(1 To j)
    SalesRep1 = uniqueNames(1)
    SalesRep2 = uniqueNames(2)
    SalesRep3 = uniqueNames(3)
Sub OpenProtectedSheet1()
    Dim actualPassword As String
    Dim enteredPassword As String
    actualPassword = "John123"
    enteredPassword = InputBox("Enter the password to access the protected sheet:", "Password Required")
    If enteredPassword = actualPassword Then
        ThisWorkbook.Sheets("Sheet1").Unprotect Password:=actualPassword
        MsgBox "Welcome!"
        MsgBox "Incorrect password. Access denied.", vbExclamation
Sub OpenProtectedSheet2()
    actualPassword = "Jane123"
        ThisWorkbook.Sheets("Sheet2").Unprotect Password:=actualPassword
        MsgBox "Welcome!"
Sub OpenProtectedSheet3()
    actualPassword = "Mark123"
        ThisWorkbook.Sheets("Sheet3").Unprotect Password:=actualPassword
        MsgBox "Welcome!"
Sub UnhideSheet1()
Sub UnhideSheet2()
Sub UnhideSheet3()
    ThisWorkbook.Sheets("Sheet3").Visible = xlSheetVisible
VBA Code within Workbook:
Private Sub Workbook_SheetDeactivate(ByVal Sh As Object)
    Dim passwordSheet1 As String
    Dim passwordSheet2 As String
    Dim passwordSheet3 As String
    passwordSheet1 = "John123"
    passwordSheet2 = "Jane123"
    passwordSheet3 = "Mark123"
    Select Case Sh.Name
        Case "Sheet1"
            Sh.Protect Password:=passwordSheet1
            Sh.Visible = xlSheetHidden
        Case "Sheet2"
            Sh.Protect Password:=passwordSheet2
        Case "Sheet3"
            Sh.Protect Password:=passwordSheet3
    End Select
Let me know if you want to learn the whole procedure in more detail or how the code works. Stay blessed, and good luck.
daveb1967b
