Private Sub CommandButton1_Click()
Dim wsCaseNo As Worksheet
Dim wsDate As Worksheet
Dim wsCredit As Worksheet
Dim wsBalance As Worksheet
Dim wsRemarks As Worksheet
Dim lastRow, lastRowSummary As Long
Set ws = ThisWorkbook.Sheets("Summary")
Set wsCaseNo = ThisWorkbook.Sheets("Case No")
Set wsDate = ThisWorkbook.Sheets("Date")
Set wsCredit = ThisWorkbook.Sheets("Credit")
Set wsBalance = ThisWorkbook.Sheets("Balance")
Set wsRemarks = ThisWorkbook.Sheets("Remarks")
lastRow = wsCaseNo.Cells(wsCaseNo.Rows.Count, 1).End(xlUp).Row + 1
lastRowSummary = ws.Cells(ws.Rows.Count, 1).End(xlUp).Row + 1
wsCaseNo.Cells(lastRow, 1).Value = txtCaseNo.Value
wsDate.Cells(lastRow, 1).Value = txtDate.Value
wsCredit.Cells(lastRow, 1).Value = txtCredit.Value
'wsBalance.Cells(lastRow, 1).Value = txtBalance.Value
wsRemarks.Cells(lastRow, 1).Value = txtRemarks.Value
With ws
.Cells(lastRowSummary, 1).Value = txtCaseNo.Value
.Cells(lastRowSummary, 2).Value = txtDate.Value
.Cells(lastRowSummary, 6).Value = txtCredit.Value
'.Cells(lastRowSummary, 11).Value = txtBalance.Value
.Cells(lastRowSummary, 12).Value = txtRemarks.Value
Call CalculateBalance
ws.Cells(lastRowSummary, 11).Value = txtBalance.Value
If CInt(Me.txtBalance.Value) < 0 Then
Call AddCredit
Call SetDisbursalAmount
Call ClearForm
MsgBox "Data submitted successfully.", vbInformation
Sub ClearForm()
txtCaseNo.Value = ""
txtDate.Value = ""
txtCredit.Value = ""
txtAmount.Value = ""
txtBalance.Value = ""
txtRemarks.Value = ""
cmdDisbursalParty.Clear
Private Sub txtAmount_Change()
On Error Resume Next
Me.txtBalance.Value = Me.txtCredit.Value - Me.txtAmount
' If Me.txtBalance.Value < 0 Then
' Call Me.CalculateBalance
' End If
'Private Sub txtBalance_Change()
' If Right(Me.txtBalance.Value, 1) = "-" Then
' Call CalculateBalance
' End If
'End Sub
Private Sub txtCredit_Change()
Dim summarySheet As Worksheet
Dim lastRow As Integer
Set summarySheet = ThisWorkbook.Sheets("Summary")
lastRow = summarySheet.Cells(summarySheet.Rows.Count, 1).End(xlUp).Row
If lastRow <= 2 Then
Private Sub UserForm_Initialize()
Dim valueRange As Range
Dim valueArray As Variant
Dim i, lastRow As Integer
Set valueRange = summarySheet.Range("G2:J2")
valueArray = valueRange.Value
Me.cmdDisbursalParty.Clear
For i = LBound(valueArray, 2) To UBound(valueArray, 2)
Me.cmdDisbursalParty.AddItem valueArray(1, i)
Me.Label3.Caption = "Initial Credit"
Me.txtCredit.Enabled = True
Me.txtCredit.Enabled = False
Me.txtCredit.Value = summarySheet.Range("K" & lastRow).Value
Sub SetDisbursalAmount()
Dim selectedValue As String
Dim p1Sheet, p2Sheet, p3Sheet, p4Sheet, summary As Worksheet
Set p1Sheet = ThisWorkbook.Sheets("Disbursal to P1")
Set p2Sheet = ThisWorkbook.Sheets("Disbursal to P2")
Set p3Sheet = ThisWorkbook.Sheets("Disbursal to P3")
Set p4Sheet = ThisWorkbook.Sheets("Disbursal to P4")
Set summary = ThisWorkbook.Sheets("Summary")
selectedValue = Me.cmdDisbursalParty.Value
lastRowSummary = summary.Cells(summary.Rows.Count, 1).End(xlUp).Row
If selectedValue = "P1" Then
lastRow = p1Sheet.Cells(p1Sheet.Rows.Count, 1).End(xlUp).Row + 1
p1Sheet.Cells(lastRow, 1).Value = Me.txtAmount.Value
summary.Cells(lastRowSummary, 7).Value = Me.txtAmount.Value
ElseIf selectedValue = "P2" Then
lastRow = p2Sheet.Cells(p2Sheet.Rows.Count, 1).End(xlUp).Row + 1
p2Sheet.Cells(lastRow, 1).Value = Me.txtAmount.Value
summary.Cells(lastRowSummary, 8).Value = Me.txtAmount.Value
ElseIf selectedValue = "P3" Then
lastRow = p3Sheet.Cells(p3Sheet.Rows.Count, 1).End(xlUp).Row + 1
p3Sheet.Cells(lastRow, 1).Value = Me.txtAmount.Value
summary.Cells(lastRowSummary, 9).Value = Me.txtAmount.Value
ElseIf selectedValue = "P4" Then
lastRow = p4Sheet.Cells(p4Sheet.Rows.Count, 1).End(xlUp).Row + 1
p4Sheet.Cells(lastRow, 1).Value = Me.txtAmount.Value
summary.Cells(lastRowSummary, 10).Value = Me.txtAmount.Value
Sub CalculateBalance()
Dim sumP As Double
lastRow = ws.Cells(Rows.Count, 1).End(xlUp).Row
sumP = ws.Cells(lastRow, 7).Value + ws.Cells(lastRow, 8).Value + ws.Cells(lastRow, 9).Value + ws.Cells(lastRow, 10).Value
' If (ws.Cells(lastRow, 6).Value - sumP) < 0 Then
' MsgBox "Add Credit!", vbInformation
' Call AddCredit
' Exit Sub
' End If
ws.Cells(lastRow, 11).Value = ws.Cells(lastRow, 6).Value - sumP
'ws.Cells(lastRow + 1, 6).Value = ws.Cells(lastRow, 11).Value
Sub AddCredit()
Dim ws, wsCredit, wsBalance As Worksheet
Dim lastRow, lastRowCredit, lastRowBalance As Long
Dim inputValue As Long
Dim currentValue As Long
Dim temp As Long
lastRowCredit = wsCredit.Cells(Rows.Count, 1).End(xlUp).Row
lastRowBalance = wsBalance.Cells(Rows.Count, 1).End(xlUp).Row
currentValue = ws.Range("F" & lastRow).Value
inputValue = InputBox("Enter a value:")
If Not IsNumeric(inputValue) Then
MsgBox "Invalid input. Please enter a numeric value.", vbExclamation
ws.Range("F" & lastRow).Value = currentValue + inputValue
temp = ws.Range("K" & lastRow).Value
ws.Range("K" & lastRow).Value = ws.Range("K" & lastRow).Value + inputValue
wsCredit.Range("A" & lastRowCredit + 1).Value = inputValue
wsBalance.Range("A" & lastRowBalance + 1).Value = temp + inputValue
