nested if statement
Wandy
i have this issue
if (C2="annual check") {
if (D2<TODAY() print expired;
else if (D2<=TODAY()+7 print expiring soon;
else print ok;
} else if (C2="monthly check") {
else print ok;
i can work fine with "annual check" alone
but when combining with "monthly check" i have no clue how to write it.
i hope someone can help on this. Thanks in advance.
Hello Wandy,
You can combine Annual Check and Monthly Check using the OR function, since both use the same conditions for the date in D2.
=IF(D2="","",IF(OR(C2="annual check",C2="monthly check"),IF(D2<TODAY(),"Expired",IF(D2<=TODAY()+7,"Expiring Soon","OK")),""))
This formula will return:
  • Expired → if the date in D2 is before today.
  • Expiring Soon → if the date is today or within the next 7 days.
  • OK → if the date is more than 7 days away.
  • Blank → if D2 is empty or C2 is neither "annual check" nor "monthly check".
Since the conditions are identical for both check types, using OR avoids repeating the same nested IF statements.
999eejlcom
