[Solved] Print all sheets in a workbook, with same page layout format and etc
dear all,
kindly help, i need to print all sheets in a workbook, but when i do it manually, for every sheet i need to re arrange the margin, paper selection, and select printer, is there any possibility to do all this task with a macro so it will print all sheets automatically with same rules? thank you
bigMe
dear all,
bigMe
Hello BigMe
Thanks for sharing your problem. You wanted to print all sheets in a workbook with the same page layout format, etc.
I am delighted to inform you that I have developed a sub-procedure to fulfil your goal.
I am assuming your data and sheets are like the following GIF.
To print all sheets in a workbook with the same page layout format:
  1. Press Alt+F11 to open VBE.
  2. Click on Insert followed by Module.
  3. Insert the following code in the module and Run.
    Sub PrintAllSheetsWithSamePageLayout()
        For Each ws In ThisWorkbook.Sheets
            ' Add more settings as needed
            With ws.PageSetup
                .LeftMargin = Application.InchesToPoints(0.75)
                .RightMargin = Application.InchesToPoints(0.75)
                .TopMargin = Application.InchesToPoints(1)
                .BottomMargin = Application.InchesToPoints(1)
                .Orientation = xlLandscape
                .PaperSize = xlPaperLetter
                .PrintTitleRows = "$1:$1"
                .PrintTitleColumns = "$A:$B"
        Next ws
        ThisWorkbook.PrintOut
  4. In the Save Print Output As file dialog, name the pdf file and click on Save.
As a result, after opening the file, you will see an output like the following GIF.
I am attaching the solution workbook for better understanding. Good luck.
Excel & VBA Developer
  • BigMe (SOLVED).xlsm
duytoi
