[Solved] Problem with Micro
Status
Not open for further replies.
Salam, Brother Rahman
Thank you very much,for your EXPERT input, time and effort. I will check and let you how it come out
Regards to you, your team and family
Thanks, Take care. Love you all :love::love::love:
Hi Haas,
Wa alaykumu s-salam! Thank you for your message! I truly appreciate your kind words. It's wonderful to hear that you found my input valuable.
Sending my regards to you and your family. Take care and stay well!
Best regards,
Little problem needs another look at Sub StoreGapValuesWithColorBackground the result numbers do not match. PLEASE give another look
Thanks, Take Care. Love you all :love::love::love:
Dear Haas
I have reviewed the code and tested it several times. You are right about the raised issue. Currently, I am on to it. When I find a solution, I will share the idea in this thread.
Dear Haas
Thank you for being so patient and staying with ExcelDemy Forum. It's my bad! When modifying the code based on the Source and Target ranges, I failed to notice and change the lstRowSrc variable.
I am delighted to inform you that the below code will not disappoint you. I am attaching the solution workbook this time as well.
Excel VBA Code:
Sub StoreGapValuesWithColorBackground()
    Dim col As Range
    Dim colIndex As Integer
    Dim gapCount As Integer
    Dim lastGapRow As Long
    Dim coloredCellFound As Boolean
    Dim columnColor As Long
    Dim lstGP As Integer
    Set ws = ThisWorkbook.Sheets("Sheet1")
    Dim sourceData As Range
    Dim lstRowSrc As Integer
    Dim firstRowSrc As Integer
    Dim rowSrc As Integer
    Dim targetData As Range
    Set sourceData = ws.Range("A14:H28")
    Set targetData = ws.Range("S14:AA28")
    firstRowSrc = sourceData.Cells(1, 1).Row
    rowSrc = sourceData.Cells(sourceData.Rows.Count, 1).End(xlUp).Row
    lstRowSrc = rowSrc - firstRowSrc + 1
    Debug.Print lstRowSrc
    gapCount = 0
    For colIndex = 2 To sourceData.Columns.Count
        Set col = ws.Range(sourceData.Cells(1, colIndex), sourceData.Cells(lstRowSrc, colIndex))
        lastGapRow = 1
        coloredCellFound = False
        columnColor = -1
        For Each cell In col
            If Not IsEmpty(cell.Value) Then
                If cell.Interior.Color <> RGB(255, 255, 255) Then
                    If gapCount > 0 Then
                        targetData.Cells(lastGapRow, colIndex - 1).Value = gapCount
                        gapCount = 0
                        lastGapRow = lastGapRow + 1
                    coloredCellFound = True
                    gapCount = gapCount + 1
                If columnColor = -1 And cell.Interior.Color <> RGB(255, 255, 255) Then
                    columnColor = cell.Interior.Color
        If Not coloredCellFound Then
            targetData.Cells(lastGapRow, colIndex - 1).Value = 0
            gapCount = 0
        ElseIf gapCount > 0 Then
            gapCount = 0
        If columnColor <> -1 Then
            ws.Range(targetData.Cells(1, colIndex - 1), targetData.Cells(lastGapRow - 1, colIndex - 1)).Interior.Color = columnColor
    Next colIndex
OUTPUT:
Hass (OUTPUT).png​
Stay blessed. Good luck.
Thank you. I will run it and let you know the outcome. How to change ? source on sheet1 and target on sheet 2 or sheet 3. This Gap sheet will be on sheet2 or sheet3.
Thanks for all the hard work. For you its easy, I tried to figure it out but unable to do so . Two more needs your expert attention, The Sine value and forecast. I know you are a very busy person. Allah SWT make you shine in both worlds, Ameen, InshaAllah
Take Care Regards to all
:love::love::love:(y)(y)(y)
Dear Haas
Wa alaykumu s-salam! You are most welcome. You want to take the Source Data from Sheet1 and store Target Result on Sheet2 or Sheet3. To meet your new requirements, I have changed the previous code.
Source Data:
Source Data.png​
Requirement 1:
Requirement1 (SOLVED).png​
Sub CountColoredCellsWithColorBackground()
    Dim ws1, ws3 As Worksheet
    Dim col As Range
    Dim coloredCount As Integer
    Dim targetColor As Long
    Set ws1 = ThisWorkbook.Sheets("Sheet1")
    Set ws3 = ThisWorkbook.Sheets("Sheet3")
    Set sourceData = ws1.Range("A14:H28")
    Set targetData = ws3.Range("J14:P14")
    lstRowSrc = sourceData.Cells(sourceData.Rows.Count, 1).End(xlUp).Row
    coloredCount = 0
    targetColor = -1
        Set col = ws1.Range(sourceData.Cells(1, colIndex), sourceData.Cells(lstRowSrc, colIndex))
            If Not IsEmpty(cell.Value) And cell.Interior.Color <> RGB(255, 255, 255) Then
                coloredCount = coloredCount + 1
                If targetColor = -1 Then
                    targetColor = cell.Interior.Color
        targetData.Cells(1, colIndex - 1).Value = coloredCount
        If targetColor <> -1 Then
            targetData.Cells(1, colIndex - 1).Interior.Color = targetColor
            targetData.Cells(1, colIndex - 1).Font.Bold = True
        coloredCount = 0
        targetColor = -1
    Next colIndex
Requirement 2:
Requirement2 (SOLVED).png​
    Dim col As Range
    Set targetData = ws3.Range("S14:AA28")
    gapCount = 0
        lastGapRow = 1
        columnColor = -1
                        gapCount = 0
            gapCount = 0
            gapCount = 0
            ws3.Range(targetData.Cells(1, colIndex - 1), targetData.Cells(lastGapRow - 1, colIndex - 1)).Interior.Color = columnColor
    Next colIndex
Download the solution workbook for a better understanding. Good luck.
Dear Haas
I am sorry to inform you I cannot understand the problem regarding FORECASTING VALUES and SINE CURVE VALUES. I do not have the proper concept of how to calculate it manually. If I knew how to calculate these values mathematically, maybe I could develop the idea within Excel VBA. For now, I am giving you some codes that may help you.
FORECASTING VALUES:
Sub CalculateForecastValues()
    Dim sourceRange As Range
    Dim targetRange As Range
    Dim col As Long
    Dim hiValue As Double
    Dim midValue As Double
    Dim lowValue As Double
    Set sourceRange = Worksheets("Sheet2").Range("B43:H53")
    Set targetRange = Worksheets("Sheet2").Range("M43:S47")
    For col = 1 To sourceRange.Columns.Count
        hiValue = WorksheetFunction.Max(sourceRange.Columns(col))
        midValue = WorksheetFunction.median(sourceRange.Columns(col))
        lowValue = WorksheetFunction.Min(sourceRange.Columns(col))
        targetRange.Cells(1, col).Value = hiValue
        targetRange.Cells(3, col).Value = midValue
        targetRange.Cells(5, col).Value = lowValue
    Next col
SINE CURVE VALUES:
Sub CalculateSineCurveValues()
    Dim col As Long
    Dim row As Long
    Dim amplitude As Double
    Dim frequency As Double
    Dim phaseShift As Double
    Set sourceRange = Worksheets("Sheet2").Range("M43:S47")
    Set targetRange = Worksheets("Sheet2").Range("X43:AF47")
    amplitude = 10
    frequency = 0.1
    phaseShift = 0
        For row = 1 To sourceRange.Rows.Count Step 2
            targetRange.Cells(row, col).Value = amplitude * Sin(frequency * row + phaseShift) + sourceRange.Cells(row, col).Value
        Next row
    Next col
OUTPUT:
Demo OUTPUT.png​
Please go through the attached file and let me know. Good luck.
Thank you for everything. My brother is in ICU serious condition, Please pray for him his name is Laeeq. as soon i get chance i will check and let you know
thanks
thanks
Dear Haas,
Wa alaykumu s-salam! I'm deeply sorry to hear about your brother Laeeq's current ICU condition. My thoughts and prayers are with you and your family during this challenging time. May Allah grant him a swift and complete recovery.
Take care
Thanks for your prayers. Laeeq went back to his Creator. Allah SWT Bless him with JanatulFirdose. Ameen
Wa alaykumu s-salam Haas
I'm deeply saddened to hear about Laeeq's passing. May Allah SWT grant him a place in JanatulFirdose and provide comfort and strength to you and your family.
Ameen
Sorry for not getting back to you and thanks for your kind prayer. I did not feel like doing any thing. How are you and your family?
I am attaching a .bas file for your kind, expert tweaking. This is a college project for my son, I am helping him. once upon a time, I use to be very good in excel & vba, but my mind dose not work any more.
Thanks for you time and effort in solving these problems. Allah SWT will reward you for all the help you provide to people.
Take care
It's great to hear from you again. No need to apologize at all! My family and I are doing well. Thank you for asking.
Currently, I am going through the specifications you have given in your attached file. When I am done, I will share my findings in this thread. Stay blessed!
Dear Haas
I have reviewed the attached file you gave. After Investigating the file, I noticed that your requirements are below:
  • Requirement 1: 232 Columns. and 6498 Rows of DATA. Digit length is 01 to 10,999. All calculations are done on each column
  • Requirement 2: Ignore Blanks
  • Requirement 3: Source DATA is on Sheet1
  • Requirement 4: Colored Cells count & Forecast & Sine Curve is on Sheet3
  • Requirement 5: Gaps of white cell count, Between the Colored cells is on Sheet4
I modified the previously provided sub-procedures in such a way that fulfils all the requirements except for the Forecast and Sine curve. As mentioned earlier, I have no clue about how to solve the Forecast and Sine Curve problems manually. You must provide more resources for me to study and understand the problem. Later, I will try to develop an Excel VBA procedure to solve these particular problems.
I am going to provide the VBA codes in the next replies. Here, I have also attached the solution workbook. Good luck!
Download Solution Workbook
Take care
Dear Haas
As requested, I am working with Source Data, which has 6498 rows and 232 columns. As a result, the execution time will be more than the usual running time.
1. RESULT OF SUM or COUNTS OF COLORED CELLS
Excel VBA Code
Sub CountAndColorCellsPQR()
    Dim ws1 As Worksheet
    Dim ws3 As Worksheet
    Dim columnCounter As Integer
    Dim tempColor As Long
    columnCounter = 2
    Do While columnCounter <= 233
        coloredCount = 0
        tempColor = RGB(255, 255, 255)
        For Each cell In ws1.Range(ws1.Cells(7, columnCounter), ws1.Cells(6517, columnCounter))
                If coloredCount = 1 Then
                    tempColor = cell.Interior.Color
        ws3.Cells(7, columnCounter - 1).Value = coloredCount
        If tempColor <> RGB(255, 255, 255) Then
            ws3.Cells(7, columnCounter - 1).Interior.Color = tempColor
        columnCounter = columnCounter + 1
    Loop
2. RESULT OF GAP or WHITE CELLS BETWEEN THE COLORED CELLS
Excel VBA Code
    Dim ws4 As Worksheet
    Dim col As Range
    Set ws4 = ThisWorkbook.Sheets("Sheet4")
    Set sourceData = ws1.Range("B7:XH6517")
    Set targetData = ws4.Range("B7:XH3000")
    colIndex = 1
    For Each col In sourceData.Columns
        gapCount = 0
        lastGapRow = 1
        columnColor = RGB(255, 255, 255)
        For Each cell In col.Cells
                    If coloredCellFound Then
                        targetData.Cells(lastGapRow, colIndex).Value = gapCount
                    gapCount = 0
        targetData.Columns(colIndex).Interior.Color = columnColor
        colIndex = colIndex + 1
    Next col
Good luck!
Thank you very much for reply, I will let you know the result. Allah SWT have Blessed you with much of potential. keep it up and be thankful for every moment, you will shine like a star. InshaAllah
Thanks to you and your team for excellent work
Take Care
Thank you very much for you time and effort. My son Noah have to submit the project by Oct 20th 2023. i know you are very busy person and I appreciate. the count of color cells worked fine. The problem is with the gap VBA, I am attaching the sheet for your consideration
Thank you again
Take Care
Thanks for your nice word. Your appreciation means a lot to us. May Allah bless you as well.
We are always here to assist. So do not hesitate to reach out any time.
Dear Haas
Thanks for Thanking. After seeing the project, I will let you know whether I can do it alone or not.
Currently, I am going through the issue that arises with the sub-procedure responsible for calculating the Gap between the colored cells. When I am done, I will share the idea here.
Thank you again
Hello Haas
I went through the attached file. You wanted to put R instead of 0 if there are no gaps between the colored cells. I have made a few changes to return R instead of 0 and overcome other issues.
RESULT OF GAP or WHITE CELLS BETWEEN COLORED CELLS
Excel VBA Code
Sub RStoreGapValuesWithColorBackground()
    Dim col As Range
    Set ws1 = ThisWorkbook.Sheets("Test Source")
    Set ws4 = ThisWorkbook.Sheets("Test Destination")
    Set sourceData = ws1.Range("B7:Z100")
    Set targetData = ws4.Range("B7:Z110")
    colIndex = 1
        gapCount = 0
        lastGapRow = 1
                        If gapCount = 0 Then
                            targetData.Cells(lastGapRow, colIndex).Value = "R"
                    gapCount = 0
    Next col
I am attaching the solution workbook as well. Good luck!
Download Workbook
Status
alfredgforrestr
