[Solved] save it and set path
reza_akbar
Sub SaveIt()
Dim dt As String, wbNam As String
wbNam = "Log book"
dt = Format(CStr(Now), "yyyy_mm_dd_hh_mm")
ActiveWorkbook.SaveAs Filename:=wbNam & dt
how to make save in set path, like D:\file magang\hasil magang vba
Dear reza_akbar,
To save the file in a specific path, you must include the folder path, file name, and extension in the Filename argument of the SaveAs method. The modified code is given below:
Sub SaveIt()
    Dim dt As String, wbNam As String, savePath As String
    'Enter your workbook name
    wbNam = "Log book"
    'Enter your required file path
    savePath = "D:\file magang\hasil magang vba\" & wbNam & dt & ".xlsm"
    ActiveWorkbook.SaveAs Filename:=savePath
I hope this resolves your problem. Let us know your feedback.
