[Solved] Sequence Function Issue
afoster
I have followed the instructions in How To Create a Credit Card Payment sheet and everything is working except that the rows are not hidden if the value in column b is empty. This is because the tutorial uses the Sequence function and my version of Excel does not allow the sequence function. Therefore, the VBA code that is inserted in the spreadsheet is not working. Is there a way around this or am I just stuck with what I have? Great tutorial by the way.
Also, I can't seem to figure out how to display cells in red background if the value is a negative number.
Hello Afoster
Welcome to ExcelDemy Forum! Thanks for reaching out and sharing your problem.
You mentioned that your Excel version does not have the SEQUENCE function. Do not worry! I have come up with a solution that generates sequences based on the number of payments using an Excel VBA User-defined function. Besides, you wanted to learn how to display cells with a red background if the value is a negative number. To do so, I have developed the Worksheet_Calculate event procedure.
SOLUTION Overview:
Output of using Excel VBA user-defined function to generate sequence and using Excel VBA event...gif
Follow these steps:
  1. Press Alt+F11 to open the VBA editor.
  2. Click on Insert followed by Module.
  3. Paste the following code in the module and save it:
    Function GenerateSequence(ByVal numberOfPayments As Long) As Variant
        Dim roundedPayments As Long
        Dim sequence() As Variant
        roundedPayments = Round(numberOfPayments, 0)
        ReDim sequence(1 To roundedPayments, 1 To 1)
        For i = 1 To roundedPayments
            sequence(i, 1) = i
        GenerateSequence = sequence
  4. Return to the sheet and select the intended cell.
  5. Insert the following formula and hit Enter:
    =GenerateSequence(H7)
  6. Open the VBA editor again and right-click on sheet1 from the Microsoft Excel Object list.
  7. Later, click on View Code, paste the following code into the sheet module and save it:
    Option Explicit
    Private Sub Worksheet_Change(ByVal Cell_Target As Range)
        Dim Cell_Range As Range
        Application.ScreenUpdating = False
        For Each Cell_Range In Range("B7:B100")
            If Cell_Range.Value = "" Then
                Cell_Range.EntireRow.Hidden = True
                Cell_Range.EntireRow.Hidden = False
        Next Cell_Range
        Application.ScreenUpdating = True
    Private Sub Worksheet_Calculate()
        For Each cell In UsedRange
            If IsNumeric(cell.Value) And cell.Value < 0 Then
                cell.Interior.Color = RGB(255, 0, 0)
                cell.Interior.ColorIndex = xlColorIndexNone
I hope you have found the solution helpful. I have also attached the solution workbook; good luck.
Excel & VBA Developer
Thank you so much for your help. I am still having trouble thought and I imagine is that I am not doing it right. Which cell do you mean when you say "Select intended cell" in number 4. Also, even though I add the code for the module, there is no listed module when I view the macros. Is it not supposed to be there?
As for the spreadsheet you attached, I am getting an error message that says:
Ambiguous name detected: GenerateSequence
Dear Afoster
Thanks for thanking me. You were almost there. However, you faced several problems. Do not worry! I will try to explain the procedures more clearly.
Let us discuss your first problem. In my previous reply, I tried to refer to cell B5 by writing the intended cell (in step 4).
Now, let us solve the error you mentioned earlier. The "Ambiguous Name Detected: GenerateSequence" error means there is a problem because the workbook has two user-defined functions named "GenerateSequence."
So, assuming I already added the code for the GenerateSequence user-defined function in module 1 in my attached file, when you downloaded the file, you inserted another module and added the code again. It seems you are an Error like the following GIF:
Solution:
  1. In module 1, keep the source code of the GenerateSequence user-defined function.
  2. Keep the code responsible for raising events in the sheet module of sheet 1.
    Output of using the user-defined function and event procedures to generate sequence of numbers.gif
Hopefully, you understand why you are getting in trouble; good luck.
In following your second directions, I get the following error message when I try to copy the value in cell b5 to b24. I also get the same error message when I try to change any of the values in column H of your solved spreadsheet.View attachment 1358
My version of Excel is 2010 and I am wondering if that is the cause of the error messages and problems I am having getting this to work.
Dear Afoster
Perhaps the Excel Version is not the reason. The Worksheet_Calculate event is available in almost all versions of Excel VBA, including the most widely used versions, including Excel 2003 and onwards (2007, 2010, 2013, etc.).
Do not worry! Currently, I am investigating your problem. Hopefully, I will come up with an idea. Stay connected.
Dear Afoster
Thanks for staying with ExcelDemy Forum. I have found the reason why you are having trouble. You are getting an error on the highlighted line because you are not correctly using the GenerateSequence user-defined function in cell B4. You do not need to copy the formula down to cell B24 using the Fill Handle or double-clicking. All you need to do is insert the formula in cell B4.
So, before following the previous 2nd instruction, you must generate the sequence in column B [in other words, before pasting codes of the event procedures (Worksheet_Change and Worksheet_Calculate) in the sheet module of sheet1].
Follow these steps:
  1. Select cell B4.
  2. Insert the following formula:
  3. Hit Enter.
As a result, you will see an output like the following GIF.
Hopefully, following the idea, you will overcome your situation; good luck.
I have set up another spreadsheet from the start and only added the vba code for the module before entering the vba code that goes into the Sheet1 area. When I enter the formula =GenerateSequence(H7) it only adds the number 1 in the first cell of the B column, directly under the heading Month. Any other ideas?
Dear Afoster
Thanks for staying with ExcelDemy Forum! I have reviewed your problem and come up with a solution. I have made two Excel VBA Sub-procedures and called them in a Worksheet_Change event.
So, instead of using the GenerateSequence user-defined function, all you need to do is put the following code in the sheet module and save it. Later, go to the sheet and make changes to see an output like the following GIF:
Excel VBA Event Procedure:
Option Explicit
Public Sub PopulateValues()
    Dim i As Integer
    Dim numPayments As Integer
    Dim currentRow As Integer
    Set ws = ThisWorkbook.Sheets("Sheet1")
    numPayments = Round(ws.Range("H7").Value)
    currentRow = 5
    For i = 1 To numPayments
        ws.Cells(currentRow, 2).Value = i
        currentRow = currentRow + 1
Public Sub RemoveMonth()
    lastRow = ws.Cells(ws.Rows.Count, "B").End(xlUp).Row
    If lastRow >= 5 Then
        ws.Range("B5:B" & lastRow).ClearContents
    If Not Intersect(Target, ws.Range("H4:H8")) Is Nothing Then
        Call RemoveMonth
        Call PopulateValues
    For Each Cell_Range In ws.Range("B7:B100")
    Next Cell_Range
I hope the solution will help you overcome your situation. I have attached the solution workbook; good luck.
It works! Thank you so much.
I noticed that if I enter any information that requires a number of payments over 20, the month column (Column B) populates, but columns C, D and E do not populate beyond row 20. Can that be corrected and if so how do I do it?
Dear Afoster, Thanks for letting us know that the previously provided VBA Sub-Procedure and Event procedure worked perfectly on your end.
I have improved the file and fulfilled your requirements by dragging the existing formulas for the C, D, and E columns up to 100 rows. Please check the following:
I have attached the workbook. Stay connected. Good luck.
ExcelDemhy
ExcelDemhy
Thanks, it does work, but it does not delete the rows below the number of payments.
ExcelDemhy
Excuse the delay in getting back to you...I see that the revised spreadsheet has 100 rows and I wanted to thank you for your help on this.
Dear Afoster, Thanks for thanking me! You are welcome. Your appreciation means a lot to us.
You are right about not deleting the rows below the number of payments; it hides the rows.
Thanks once again for letting us know that the previously provided worked perfectly as you intended. Stay blessed.
kiranpuj
