[Solved] show cells with value in listbox
dear friends,
kindly help me how to show data in range of column into listbox but only cells with value, thank you.
bigMe
dear friends,
bigMe
Hello Bigme
Thank you for posting an exciting problem. To achieve your requirement, you must insert a UserForm and a ListBox. However, I add some extra features to decorate the UserForm you may like.
Steps:
Consider a dataset >> insert a button.
Open the VBA editor >> insert a UserForm.
Create and design a Label and a ListBox within UserForm.
Private Sub UserForm_Initialize()
    Dim rng As Range
    Dim lstRow As Long
    Dim columnRange As String
    Set ws = ThisWorkbook.Worksheets("Sheet1")
    lstRow = Cells(Rows.Count, 2).End(xlUp).Row
    columnRange = "B2:B" & lstRow
    Set rng = ws.Range(columnRange)
    Me.Label1.Caption = ws.Range("B1").Value
    For Each cell In rng
        If Not IsEmpty(cell.Value) Then
            Me.ListBox1.AddItem cell.Value
Double-click on the UserForm area and paste the below code.
Now, insert a Module and paste the below code.
Sub showList()
    UserForm1.Show
Later, assign the procedure stored in the module.
Output: You can see an overview of the whole feature by clicking the link below.
I have attached the solution workbook to help you understand better. Feel free to contact us again if you have more queries. Good luck!
Dear Lutfor,
thank you very much for your help...., can i ask for little more favor ? :giggle:
if i change the source become 2 column and only show into list box the complete one only, which part of the code needs modification? thank you.sshot.JPG
bigMe
Dear Lutfor,
if i change the source become 2 column and only show into list box the complete one only, which part of the code needs modification? thank you.View attachment 610
bigMe
Hello Bigme,
Thanks for your query. You want to show a list of two columns. I can give a modified version of my previous code. That will fulfil your goal. All you need is to replace the UserForm initialize event with the following code.
    Set ws = ThisWorkbook.Sheets("Sheet1")
    lastRow = ws.Cells(ws.Rows.Count, "B").End(xlUp).Row
    With Me.ListBox1
        .ColumnCount = 2
        .ColumnWidths = "75, 50"
        For i = 2 To lastRow
            If ws.Cells(i, "B").Value <> "" And ws.Cells(i, "C").Value <> "" Then
                .AddItem
                .List(.ListCount - 1, 0) = ws.Cells(i, "B").Value
                .List(.ListCount - 1, 1) = ws.Cells(i, "C").Value
However, I will introduce an advanced idea to reach the same idea. When I am done, I will share the idea in this thread.
Dear Lutfor,
bigMe
Hi Bigme,
My previous modified code has a limitation. To be more specific, there is no column header in ListBox. To get the output you have shown, I have implemented three sub-procedures named ShowList, FilterAndCopyData and DeleteSheetTemp. All you need is to paste these in module1. Later, insert a button and assign the ShowList macro to it.
Module1:
Sub ShowList()
    UserForm1.Show
Sub FilterAndCopyData()
    Dim newWs As Worksheet
    Dim filterRange As Range
    Dim copyRange As Range
    Set newWs = ThisWorkbook.Sheets.Add(After:=ws)
    newWs.Name = "sheetTemp"
    Set filterRange = ws.Range("B1:C" & lastRow)
    filterRange.AutoFilter Field:=1, Criteria1:="<>", Operator:=xlAnd
    filterRange.AutoFilter Field:=2, Criteria1:="<>"
    filterRange.SpecialCells(xlCellTypeVisible).Copy newWs.Range("A1")
    newWs.Visible = xlSheetHidden
Sub DeleteSheetTemp()
    On Error Resume Next
    Set ws = ThisWorkbook.Sheets("sheetTemp")
    On Error GoTo 0
    If Not ws Is Nothing Then
        Application.DisplayAlerts = False
        ws.Delete
        Application.DisplayAlerts = True
Likewise, create an UserForm and insert a ListBox in it. Now, double-click on the UserForm area and paste the following code.
UserForm1:
    Call Module1.FilterAndCopyData
    lastRow = ws.Cells(ws.Rows.Count, "A").End(xlUp).Row
    With Me.ListBox1
        .ColumnCount = 2
        .ColumnHeads = True
        .rowSource = ws.Name & "!A2:B" & lastRow
Private Sub UserForm_QueryClose(Cancel As Integer, CloseMode As Integer)
    Call Module1.DeleteSheetTemp
Output:
I am attaching the solution workbook to help you understand better. If you have any more questions, don't hesitate to contact us.
  • Bigme(SOLVED).xlsm
wow...amazing....
thank you very much, what you share beyond my expectation (y) (y) (y) (y) (y) (y)
best regards,
bigMe
Dear Bigme,
Thank you so much for your kind words! I'm thrilled you found the information shared in the thread very helpful. Your appreciation truly means a lot to me.
Best regards,
