[Solved] Disable list option on drop down in data validation base on other cells value
dear all,
kindly help me to do my task, i have a table if i entry a value in column A then in column B make a drop down using data validation it will show only value that related to column A value, herewith i attach the sample file, thank you.
regard,
bigMe
dear all,
regard,
bigMe
Hello BigMe
Thanks for posting your comment with such clarity.
Based on the cell values of column A, you want to create or clear a drop-down list in the corresponding cells of column B.
I am delighted to inform you that I have developed such an idea that will fulfil your requirements. To do so, I have used Excel formulas implemented by combining IF, FILTER and TEXTJOIN functions. I had to develop an event procedure as well as a sub-procedure.
Follow these steps:
Step 1: Select cell O2 => Insert the following formula => Drag the Fill Handle icon to O8.
Excel Formula:
=TEXTJOIN(", ",TRUE,IF(A2="","",IF(A2="meat",FILTER($J$2:$J$6,$I$2:$I$6="meat"),IF(A2="Fruits",FILTER($J$2:$J$6,$I$2:$I$6="Fruits"),FILTER($J$2:$J$6,$I$2:$I$6="vegetable")))))
Select cell O2, insert the given formula and drag the formula down.png​
Select the entire column O => Right-click on the column name => Click on Hide.
Select the entire O column and hide this column.png​
Step 2: Right-click on the sheet name tab => Click on View Code.
Right-click on sheet name tab and click on View Code.png​
Step 3: Paste the following code in the sheet module => Click on the Save icon.
Excel VBA Sub-Procedure:
Sub CreateDropDownList()
    Dim LastRowA As Long, LastRowO As Long
    Dim WS As Worksheet
    Dim DropdownRange As Range
    Set WS = ThisWorkbook.Sheets("Sheet1")
    LastRowA = WS.Cells(WS.Rows.Count, "A").End(xlUp).Row
    LastRowO = WS.Cells(WS.Rows.Count, "O").End(xlUp).Row
    For Each cell In WS.Range("A2:A" & LastRowA)
        If Not IsEmpty(cell.Value) Then
            Dim ValueInO As String
            ValueInO = ""
            On Error Resume Next
            ValueInO = WS.Cells(cell.Row, "O").Value
            On Error GoTo 0
            If ValueInO <> "" Then
                Set DropdownRange = WS.Cells(cell.Row, "B")
                With DropdownRange.Validation
                    .Delete
                    .Add Type:=xlValidateList, AlertStyle:=xlValidAlertStop, Operator:= _
                    xlBetween, Formula1:=ValueInO
                    .IgnoreBlank = True
                    .InCellDropdown = True
                    .ShowInput = True
                    .ShowError = True
Excel VBA Event Procedure:
    Dim rng As Range
    If Not Intersect(Target, Me.Range("A:A")) Is Nothing Then
        Application.EnableEvents = False
        For Each cell In Target
            If cell.Column = 1 And cell.Row >= 2 Then
                If cell.Value = "" Then
                    Me.Cells(cell.Row, "B").ClearContents
                    Me.Cells(cell.Row, "B").Validation.Delete
                    Call CreateDropDownList
        Application.EnableEvents = True
Paste code in sheet module and Save.png​
OUTPUT:
BigMe (SOLVED).gif​
I have also attached the solution workbook to help you understand better. Good luck!
dmplaygamesio
